FE Technical Forum
Piston ring file
Topic: Piston ring file (Read 2849 times)
Skeeter65
Jr. Member
Piston ring file
May 30, 2023, 07:19:01 PM »
What inexpensive ring file is the best to go with? I see several options from summit, jegs and speedway motors but they are all pretty much the same imported piece.
Katz427
Sr. Member
Re: Piston ring file
Reply #1 on:
June 01, 2023, 05:25:54 AM »
They are all about the same or even the same part. The cutting wheel is OK for ductile iron rings, but steel rings wear them out quickly. So you need a replacement cutting wheel or two. I am assuming you are referencing the hand crank models.
Reply #2 on:
June 02, 2023, 04:21:44 PM »
I have a nice straight fine tooth file that I clamp in a vice and manually file rings. Been doing that for years without problems. I just push the ring gap down the file, never pull. I count strokes, then buff the edges with a fine Arkansas whet stone. Yea, I've looked at all the ring filers and some are really nice but I just can't seem to justify the outlay. IMHO there's a kinda "zen" to hand ring filing.
Chris - Merkel, TX
http://raceabilene.com/kelly/hotrod
Reply #3 on:
June 02, 2023, 07:13:48 PM »
I'm a hand filer as well. Seen it get away from guys and once you remove material there's no putting it back.
Keith. KB MAX Racing.
Skeeter65
Jr. Member
Reply #4 on:
June 03, 2023, 07:23:16 PM »
Thanks all. I’m a first timer to ring filing as I’ve always done stock rebuilds non custom parts and my first FE.
FE Technical Forum
Piston ring file
