Author Topic: Lykins Motorsports 496ci FE Setup For Forced Induction  (Read 7373 times)
« on: March 28, 2023, 08:05:41 AM »
Dyno'd this one naturally aspirated, but it's built for a centrifugal supercharger.  Application is designed around MPFI, centrifugal supercharger, and an intercooler, but we just slapped a carburetor on it and dyno'd it.  No tuning whatsoever, just pulls to seat the rings and check for leaks.
Performance Summary:
      Cubic Inches:   496            Dyno brand:  Stuska
      Power Adder:    N/A on dyno           Where dynoed:  Dale Meers Racing Engines
      Peak Horsepower:  594 @ 6000
      Peak Torque: 566
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  BBM cast iron, 4.310" bore size
   Crankshaft brand, cast or forged, stroke, journal size:  Scat 4340 4.250"
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  K1 6.700"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Custom Diamond, forged, 50cc dish, 8.5:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:
   Piston rings brand, size, other notes:  Total Seal, 1.5/1.5/3mm
   Oil Pump, pickup, and drive:  Melling M57HV, Canton pickup for rear sump
   Oil pan, windage tray, oil filter adapter:  Canton rear sump
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Lykins Motorsports custom solid roller
   Lifters brand, type:  Morel, pressure fed
   Timing chain and timing cover:  Cloyes billet, factory cover
   Cylinder heads brand, material, port and chamber information:  Hand ported BBM
   Intake valve brand, head size, stem size:  Ferrea 2.190", 11/32"
   Exhaust valve brand, head size, stem size:  Ferrea, 1.650", 11/32", Inconel
   Valve springs brand, part number, specs:  Manley Nextek
   Retainers and locks brand, part number, specs: Manley titanium
   Rocker arm brand, type (adjustable or non-adj), material, ratio: T&D paired rocker system
   Rocker shafts and stands, brand, material:
   Pushrods brand, type, length:  Custom Trend
   Valve covers, brand, type:  Blue Thunder
   Distributor brand, advance curve information:  N/A
   Harmonic balancer brand:  Powerbond SS
   Water pump brand, type (mechanical or electric):  CVR electric
   Intake manifold brand, material, porting information:  Hand ported Victor FE
   Carburetor(s) brand, type:  Dyno'd with Holley 830
   Exhaust manifolds or headers brand, type:  Dyno headers
« Last Edit: March 28, 2023, 08:47:32 AM by blykins »
Re: Lykins Motorsports 496ci FE Setup For Forced Induction
« Reply #1 on: March 28, 2023, 05:10:26 PM »
8.5 to 1 almost 600 horse nice, should be a beast with a supercharger. Why’s it going in.
« Reply #2 on: March 28, 2023, 05:24:38 PM »
Pickup truck.
Customer is a forum member, maybe he will chime in.
XR7
« Reply #3 on: March 28, 2023, 05:47:29 PM »
I am curious about the head gaskets, are those the SCE MLS or Cometic? Have you used the SCE yet?Likes or dislikes if so? I can't say that I have ever seen the weird bump or radius at 12 O'clock on the cylinder, what is that for?
« Reply #4 on: March 29, 2023, 04:44:40 AM »
I use both SCE and Cometic, can't go wrong with either.  These were Cometics.
JamesonRacing
« Reply #5 on: March 31, 2023, 06:50:22 AM »
Plans in the works to apply the boost later and run it again on the dyno?
This first run is just a tease :)
« Reply #6 on: March 31, 2023, 11:46:21 AM »
He will get it in the truck, put the supercharger and intercooler on, along with the EFI, then chassis dyno it.
gdaddy01
« Reply #7 on: April 03, 2023, 08:18:39 PM »
what is the peanut butter on the pistons?
« Reply #8 on: April 03, 2023, 08:49:49 PM »
peanut butter thats funny. probably ceramic or the same material he coats his bearings in. another guess its for the extra pressure the motor will see with the supercharger.
protects agains heat.
« Reply #9 on: April 04, 2023, 04:32:26 AM »
Ceramic crown coating for high heat situations.
6667fan
  • Every Second Counts
« Reply #10 on: April 04, 2023, 08:14:27 AM »
600 hp with that compression NA?
Yikes!
What kinda ring pkg called for?
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
« Reply #11 on: April 04, 2023, 09:17:48 AM »
Yikes!
1.5/1.5/3mm with an AP steel ring set.
gdaddy01
« Reply #12 on: April 04, 2023, 05:06:51 PM »
I figured it is a coating, it just looks different than the grays and blacks, looks better to me . is there some good data on the effectiveness of coatings? very nice looking builds, thanks for sharing.
« Reply #13 on: April 05, 2023, 08:00:53 AM »
This coating is the Calico HPT coating.  It protects to temperatures above 2000°F.  Just an added layer of protection for an aluminum piston, since this is going to be a higher boost on pump gas.
hbstang
« Reply #14 on: April 17, 2023, 10:59:23 AM »
is calico the brand of coating you use and do you recomend them?what about skirt coatings as well for a short piston and long stroke?
