Author Topic: Bullock's Power Service - 465 inch CJ - 475 HP at 5500 RPM  (Read 7044 times)
« on: March 18, 2023, 10:53:10 AM »
Performance Summary:
      Cubic Inches:  465           Dyno brand: Land and Sea Dynomite
      Power Adder:                    Where dynoed:  Willard Auto Machine, Omaha, NE
      Peak Horsepower:  477 @ 5500 (471  @ 5950)
      Peak Torque:  524 @ 4000
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Factory 428 C scratch  4.175
   Crankshaft brand, cast or forged, stroke, journal size: Cast SCAT 4.25
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  SCAT I-beam 6.70
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR: Racetec, 4032 Forged, -22 cc, 10:2
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Clevite rod and main bearings, Durabond cam bearings
   Piston rings brand, size, other notes:  Mahle 1mm / 2mm standard tension
   Oil Pump, pickup, and drive:  Melling M57HV, Milodon pickup, Melling HP drive
   Oil pan, windage tray, oil filter adapter:  Milodon 31130, factory oil filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Bullocks hyd roller, 235 intake duration / 242 exhaust duration, 114 LSA on 107
   Lifters brand, type:  Morel standard travel
   Timing chain and timing cover: Cloyes 9 position, factory timing cover
   Cylinder heads brand, material, port and chamber information:  Factory CJ C8OE-N, unported
   Valve springs brand, part number, specs:  977-16 Comp 155 closed, 405 open
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Harland Sharp Adjustable
   Rocker shafts and stands, brand, material:  Harland Sharp shafts, Precision Oil Pump stands
   Pushrods brand, type, length:  Smith Brothers, 3/8 cup, 5/16 ball, non oiling  .080 wall , length, 8.400
   Valve covers, brand, type:   1970 CJ - baffles removed by owner
   Distributor brand, advance curve information:  Pertronix 2 billet
   Harmonic balancer brand:  Factory CJ rebuild
   Water pump brand, type (mechanical or electric):   Tuff Stuff iron  - electric powered on dyno
   Intake manifold brand, material, porting information:  Blue Thunder CJ - unported
   Carburetor(s) brand, type:  DOZF-AB CJ Automatic, stock jetting, no spacer,  gasket only
   Exhaust manifolds or headers brand, type:  Dyno headers, 1 7/8 truck, 3 inch collector
« Last Edit: March 18, 2023, 11:36:22 AM by My427stang »
Re: Bullock's Power Service - 465 inch CJ - 475 HP at 5500 RPM
« Reply #1 on: March 18, 2023, 11:07:59 AM »
This was an interesting one, lots of variables changed from my normal routine, some not changed
Most important was the new dyno, I did this one locally because we had to deliver quickly.  It's very hard to compare one dyno to another, but it came up with a realistic number, although I think a little stingy, need to do another on it to see how to compare.  What I was not fond of was the correction factor, no excuses, but we went from a sunny day to snow squalls and dropping atmospheric pressure but the dyno didn't change it's correction.  Regardless, the numbers are what the machine told us, and with approx a 250 cfm head, it's using it all
This one was a set of iron heads with 11/32 valves, no porting, early BT CJ intake, also no porting, no spacers because of it being a shaker car, and a bone stock 70 CJ carb, even jetting was stock although I am running a 7.5 PV.  Turned out pretty nice, a/f was rock solid at 12.5/12.7 through the pull, although we did use all of that carb, it made lots of idle vacuum with 114 LSA and carried the HP within 4 hp from 5500 peak to 6000, torque was above 500 ft lbs from 3300-4500
This is going in a A/C C-6 PB street Mach, so it will be a monster compared to it's broken 428.  However, like the old "stone soup story"...some head, more overlap, some spacer, modern carb, etc
Regardless, neat to see that a set of unported heads and intake with a 735 and a mild mannered vacuum and idle requirement can make 100+ HP over a decent running CJ
410bruce
« Reply #2 on: March 18, 2023, 01:35:46 PM »
That's a nice engine, Ross. Excellent street engine as it makes all its power by 5500. That Mustang's gonna rip.  :)
John 3:16
Sand hauler
« Reply #3 on: March 22, 2023, 03:24:29 PM »
Very nice job Ross, by the way where did you find a set of 1 7/8 truck headers? Been looking for some for mine
Bobby-   Carlsbad, NM
« Reply #4 on: March 22, 2023, 09:53:01 PM »
Wish I knew what they were, swap meet specials
WerbyFord
« Reply #5 on: June 28, 2023, 02:45:58 PM »
Any dimensions on the header lengths?
Or cam lift?
Good to see the old heads get the job done, then again all those SuperStock wins came from somewhere.
« Reply #6 on: July 19, 2023, 06:09:30 AM »
I haven't been up there in a while, but they were Ford truck headers, not sure on length.  Long tube, nothing fancy
Cam lift was .588
