Author Topic: 428CJ exhaust manifolds in 67-72 F250?  (Read 4832 times)
AlanCasida
« on: November 07, 2022, 03:53:35 PM »
As I slowly return to utilizing my '67 F250 2wd as my towing truck I am looking at pulling the 390 and putting the 428CJ motor in it that I have had forever. While considering this I thought it might be cool to make it look like someone had swapped a CJ motor in it back in the day, manifolds and all. So I was wondering if anyone has tried to use those exhaust manifolds in their F100/250 and how they fit.
MRadke
Re: 428CJ exhaust manifolds in 67-72 F250?
« Reply #1 on: November 07, 2022, 05:10:11 PM »
Barry Gaugler (sp?)  used to have a manifold interchange on his Spookytruck.net website, but I don't see it there now.  Maybe drop an email to him to see whether he still has it in his files.
Dr Mabuse
« Reply #2 on: November 11, 2022, 05:20:28 PM »
Chart:
AlanCasida
« Reply #3 on: November 11, 2022, 08:57:11 PM »
Chart:
Thank you sir! Were there footnotes that went with this chart? I saw some of the "yeses" had numbers beside them.
Dr Mabuse
« Reply #4 on: November 21, 2022, 10:04:36 AM »
Try again ...
GJCAT427
« Reply #5 on: November 21, 2022, 07:00:05 PM »
 I have to admit that the 427 long tubes will fit into the 56 F100, I own one with them. You have to remove the original rear crossmember that the rear bellhousing sat on and refab a lower crossmember. I also fabbed some side mount engine mounts and a tranny mount crossmember.
Dr Mabuse
« Reply #6 on: November 22, 2022, 08:47:10 AM »
Which long tubes did you use - the '62-'64, or '65-'66?
« Reply #7 on: November 22, 2022, 02:29:17 PM »
I tried to dry fit my long tubes on my 69 f100 and knew that lower crossmember would have to be cut apart to clear things.  Even std headers are a close fit and I always cut the flanges off and use slip joints and band clamps.
Dr Mabuse
« Reply #8 on: November 22, 2022, 02:51:00 PM »
slip joints and band clamps? -- I gave up on band clamps - they always failed to hold their clamp for me - I have gone to ball-socket flange and V-band types:
GJCAT427
« Reply #9 on: November 23, 2022, 05:57:30 AM »
  I used the 62-64s
