Author Topic: Looking For a Cast Iron Cam Gear  (Read 2442 times)
Joey.S
« on: September 28, 2022, 08:41:51 AM »
 Hi guys,
 My question is I'm looking for a cast cam gear for my flat tappet cam,  Is anyone familiar with the Napa (Echlin) DG306?
 I was told it's a stock replacement gear which should be cast but I want to make sure just curious if anyone has used on of these gears it does have a much smoother finish then my original one.   I also did reach out to Brent, Barry and a couple other FE shops but they have no stock on Iron gears for the ford duraspark distributor  .467 shaft.
 Thanks in advance for any help.
 Joe
1965 Thunderbird 390+.030 Mild cam Terminator EFI
1966 Superformance Cobra 390+0.040 Custom cam
fe468stroker
Re: Looking For a Cast Iron Cam Gear
« Reply #1 on: September 29, 2022, 10:25:36 AM »
I think it would be safe to assume that it is a stock type replacement gear (cast).  If it were steel it would be triple the price.  Try contacting the manufacturer to verify.
Faron
« Reply #2 on: September 29, 2022, 11:18:14 AM »
Standard Ign DG18
Joey.S
« Reply #3 on: September 29, 2022, 03:50:21 PM »
Hi,
 Thanks for  the reply guys,  I found out today the Napa DG306 is the same as the standard ign DG18.
 I just wanted to be 120% sure I had the right gear.
 Joey.S
« Last Edit: September 29, 2022, 03:56:26 PM by Joey.S »
