FE Technical Forum
Oil pump drive size lesson
Topic: Oil pump drive size lesson (Read 7269 times)
May 15, 2013, 09:43:55 AM »
Sorry guys, more questions.
Why do FE pump drives come in two sizes (1/4, 5/16)?
I ssume 1/4 is standard, what were the applications for the 5/16?
Re: Oil pump drive size lesson
Reply #1 on:
May 15, 2013, 10:35:34 AM »
FT big truck engines ( 361, 391 ) use a 5/16 drive. Oil pump and distributor use the larger size. FE passenger car and light truck ( 360, 390 ) engines use the 1/4"
Reply #2 on:
May 15, 2013, 12:05:07 PM »
Makes sense, thanks.
Howie
Reply #3 on:
May 15, 2013, 01:20:34 PM »
You can also use a FT 5/16" drive pump on an FE with the custom drive shaft.
It's really just the same pump with a thicker hex.
Melling FE Pump specs
M-57 STD Volume Yellow Spring 40-45psi 1/4" Drive
M-57B Std Volume Brown/Plain Spring 60-65 psi 1/4" Drive
M-57HP Std Volume Big Blue Spring 100-110 psi 1/4" Drive
M-57HV High Volume Brown/Plain Spring 60-65 psi 1/4" Drive
M-57A Std Volume Brown/Plain Spring 60-65 psi 5/16" Drive
M-57AHV High Volume Brown/Plain Spring 60-65 psi 5/16" Drive
Last Edit: May 15, 2013, 01:23:10 PM by ScotiaFE
Reply #4 on:
May 15, 2013, 02:37:52 PM »
As a matter of fact I just ordered one from Precision
Last Edit: May 15, 2013, 11:36:01 PM by turbohunter
FE Technical Forum
