Author Topic: 62 Falcon  (Read 54773 times)
newfalconowner
Re: 62 Falcon
« Reply #45 on: September 23, 2015, 06:24:22 AM »
its a 68 fairlane 390 toploader, with a  Lakewood scattershield
newfalconowner
Re: 62 Falcon
« Reply #46 on: February 24, 2016, 09:09:47 PM »
here is the car in spray can black :)
cut the old driver rocker panel pieces off (3 separate pieces),, and set up and welded the one I took off a parts car.. soon as I clean off the car and drive it outside,, I will get a better picture of the whole car.. Will be the first time I can take pictures of both sides and not be ashamed :)
the motor as it looks
newfalconowner
Re: 62 Falcon
« Reply #47 on: July 03, 2016, 05:32:20 AM »
have the rear window and front windshield in now. The car hasn't had a windshield in 8yrs,, so big day :)
also interior is in,, seats and most carpets,, waiting on the ebrake handle and then finish carpeting and painting
I have all my fuel lines ran, floor is all complete, ebrake cables and rear brake lines ran,  front end is cleaned up, brake lines secured  and painted, just waiting for new oil pump and pushrod to show up then the new canton oil pan can go on and motor/trans can be installed
then hopefully get it safetied and drive the hell out of it :)
newfalconowner
Re: 62 Falcon
« Reply #48 on: July 03, 2016, 05:44:03 AM »
bent a piece of metal for the rear lower tail light panel, and cut out the rusted part. just abit of fill and paint,
also extended the tips of the sidepipes so they stick out abit, looks a lot better. bit of bodywork and good to go
front seats in,
Bolted to Floor
Re: 62 Falcon
« Reply #49 on: July 04, 2016, 03:42:39 PM »
Gotta love progress. Looking Good.
newfalconowner
Re: 62 Falcon
« Reply #50 on: July 09, 2016, 03:06:11 PM »
motor is back in, finishing up the tunnel ram then bolting it in and wire it up. if it doesn't work I always have the dual quad to fall back on
newfalconowner
Re: 62 Falcon
« Reply #51 on: July 31, 2016, 06:26:49 AM »
coming together slowly. I did try and start it yesterday but my battery is toast, so will take one out of my daily driver.. video to follow if it starts.. good news is no fuel leaks around the injectors or rails :)
« Last Edit: July 31, 2016, 06:29:54 AM by newfalconowner »
Re: 62 Falcon
« Reply #52 on: July 31, 2016, 07:38:31 AM »
Quote from: newfalconowner link=topic=1088.msg42991#msg42991 date=1469964409.. good news is no fuel leaks around the injectors or rails :)
[/quote
Great Stuff!
This must be the first time you put pressure to the rails?
I always wondered if they would hold. ;)
Hope to see you bring it in town for some cruise night or something.
newfalconowner
Re: 62 Falcon
« Reply #53 on: July 31, 2016, 08:02:52 AM »
no I did last fall and the rails held up great. just the tubes were off set and all different planes,, so I got my friends dad to tig new bungs on, and he remembered he sucked at tig welding and melted all my new bungs. So I bought new tubes and used the spool gun at work and  put them at the angle so my throttle cable would fit proper.. Ive got a lot of flack for having them at an angle but we will see if it works. I got a new pressure regulator and it works proper and not feeding fuel into my engine so that's a bonus.
I do plan on getting it on the road in august and driving it, at least to work and around
Re: 62 Falcon
« Reply #54 on: July 31, 2016, 08:37:55 AM »
It will work fine with the injectors at an angle like that.  The angle is not that extreme; I've seen setups where the runner is nearly horizontal and the injectors are vertical, and they don't have any problem.
newfalconowner
Re: 62 Falcon
« Reply #55 on: August 22, 2016, 05:58:39 PM »
got my new rims finally mounted
Pentroof
Re: 62 Falcon
« Reply #56 on: August 24, 2016, 05:22:54 PM »
You may want to throw a couple clamps on the bypass hose before to try to start it again.
Jim
newfalconowner
Re: 62 Falcon
« Reply #57 on: August 24, 2016, 06:17:25 PM »
good eye.  :)
newfalconowner
Re: 62 Falcon
« Reply #58 on: September 21, 2016, 07:35:33 PM »
rear half of my cage is done
fastback 427
Re: 62 Falcon
« Reply #59 on: September 26, 2016, 10:27:27 AM »
Looking good. I like how you ran the cage behind the fuel cell. Thanks for the updates.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
