Author Topic: 62 Falcon  (Read 54759 times)
NewFalconOwner
Re: 62 Falcon
« Reply #15 on: November 05, 2013, 06:57:00 PM »
got a 64 Falcon racing apron to try out on my 62. The guy that makes them and I decided to cut it in 3 pieces incase it needed to be shortened or lengthened and to ease install. I just taped the ends up, and seems to be about 2 inches or so longer then the 62 so the 64 is wider. Anyways, spent a few minutes to mocking up the ends so get a feel to how much work I will need to make it fit right.. Once I get more time on it I will take better notes and better pictures, but till then heres a sneak peak.
NewFalconOwner
Re: 62 Falcon
« Reply #16 on: December 05, 2013, 09:12:20 AM »
I picked up a Cobra 2x4 oval air cleaner to modify. Heres the end results
NewFalconOwner
Re: 62 Falcon
« Reply #17 on: February 01, 2014, 08:54:08 PM »
got my c6AE- U heads back from the head guy today, and installed my rockers and shimmed them up.
now I have all my stuff to put the solid cam in and break it in.
hopefully couple weeks I will have it running
NewFalconOwner
Re: 62 Falcon
« Reply #18 on: February 08, 2014, 08:02:10 AM »
got all my gauges finally, abit of trimming to do still on my plate, but heres what it will look like when assembled
Re: 62 Falcon
« Reply #19 on: February 08, 2014, 03:22:06 PM »
That's going to look pretty good!  I like new style gauges in factory type surroundings...
NewFalconOwner
Re: 62 Falcon
« Reply #20 on: February 09, 2014, 08:08:04 AM »
rebuilding the carbs and waiting  8)
NewFalconOwner
Re: 62 Falcon
« Reply #21 on: February 17, 2014, 08:57:28 PM »
got my adapter today and spent some time tonite at work to trim the tunnel ram
NewFalconOwner
Re: 62 Falcon
« Reply #22 on: February 22, 2014, 03:38:45 PM »
I got my heads bolted on and torqued, so thought I would see what the intake setup would look like
Re: 62 Falcon
« Reply #23 on: February 22, 2014, 04:26:35 PM »
Looks good!  8) 8)
NewFalconOwner
Re: 62 Falcon
« Reply #24 on: February 22, 2014, 04:28:45 PM »
thanx
soon as I find a single 4 intake, I will do the cam swap and break it in with that. then try the tunnel ram once its done :)
NewFalconOwner
Re: 62 Falcon
« Reply #25 on: April 13, 2014, 06:44:07 PM »
starting to convert my tunnel ram for the intake adapter into a fuel injection unit.. mocked up the top part so far. hopefully get the injector tube holes and rails done in the next few weeks.
on with a few pictures
Re: 62 Falcon
« Reply #26 on: April 13, 2014, 10:00:38 PM »
Hey, that's pretty cool! Did you cut an oval air cleaner lid to make that top? It looks pretty neat with the fins and 427 badge.
I thought you were going with a 2x4 carb set-up? What made you change your mind? I also think you may need a bigger throttle body to feed that engine! :)
NewFalconOwner
Re: 62 Falcon
« Reply #27 on: April 14, 2014, 07:21:18 AM »
yes it was a Cobra oval air cleaner
then I ground down the Cobra
I wanted to use my scoop I made  (I really liked that one) and keep it under it instead of raising it 6 inches. I don't think it would of looked right.
I will be getting a new throttle body once its all done up,, Accel makes a 1000cfm one and will be using 42lb injectors.
NewFalconOwner
Re: 62 Falcon
« Reply #28 on: April 27, 2014, 11:11:55 AM »
Got my fuel rail holes drilled yesterday, thank you Howie (ScotiaFE) took some pictures of the rails installed with injectors. I misplaced 1 injector but they are just mockup ones anyways..
NewFalconOwner
Re: 62 Falcon
« Reply #29 on: May 04, 2014, 04:58:29 PM »
managed to find a Torker intake Friday so I will be using that to break in the cam and check for leaks,etc. till my fuel injection intake is finished.
cleaned the intake, painted my headers and motor, timing cover,etc. anyways, hoping to break in the cam next weekend. Video to follow if I get that far.
heres what it will look like in the meantime.
