Author Topic: Morel Lifter Flush  (Read 3260 times)
Thumperbird
Morel Lifter Flush
« on: March 12, 2022, 01:57:31 PM »
Since I had trash in my oil from my crank thrust bearing wear issue I am wondering if there is a way to flush Morel lifters?
I don't think you can take them apart as the pushrod seat will not clear the rivet.
I can rotate the seat pretty easily but takes a lot of force to compress, do not have a great way to test ease of and free travel so to speak to make sure they are not sticky for some reason.
Thanks.
« Last Edit: March 12, 2022, 02:05:01 PM by Thumperbird »
1968galaxie
Re: Morel Lifter Flush
« Reply #1 on: March 12, 2022, 02:39:46 PM »
If the lifter cannot be taken apart and cleaned - I would replace them.
Just my opinion. I wouldn't take the chance.
GerryP
« Reply #2 on: March 12, 2022, 02:59:23 PM »
I'd give Morel a call and see if they offer a refub program.
« Reply #3 on: March 12, 2022, 03:04:43 PM »
Morels have a really tight piston/plunger to body clearance.  It doesn't take much to crud them up.  If they weren't ticking or causing problems before you shut it down, I don't think I'd be concerned about it.
Thumperbird
« Reply #4 on: March 13, 2022, 08:04:50 AM »
No new noise that I know of before shutting down, I've always had 1 that ticked some for a minute or two after a hard run, that is making the call a bit more difficult.  New has risks as well so executive decision time I guess.
oldiron.fe
« Reply #5 on: March 13, 2022, 12:07:04 PM »
        question I have would be - bearing material would have to get by your filter and into oil passages and be pumped into lifter or material would have to find a way into lifter to cause a problem -- if roller rinse             roller should be OK -or how would material get into lifter?   trash would rinse into crankcase but not oil passages?
66' Fairlanes 427 (08/26/67- present)
66/67' Fairlanes
70' Mustang Fastback
66' Dually
