FE Technical Forum
4500 flange Dove intake
Topic: 4500 flange Dove intake (Read 4589 times)
fastback 427
Sr. Member
February 27, 2022, 12:43:44 PM »
Since Dove only made a few dominator flange intakes we welded this one up. Had a summit adapter milled 3/4" and the intake milled 3/4" then welded them. Smoothed out the plenum with a air powered mini belt sander and various carbides.
Wondering your thoughts on performance?
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
Re: 4500 flange Dove intake
Reply #1 on:
February 27, 2022, 01:11:57 PM »
Nice work, I'm sure it will be just fine. I'm guessing you were fighting for hood clearance and not able to use a HVH adapter.
Keith. KB MAX Racing.
fastback 427
Sr. Member
Reply #2 on:
February 27, 2022, 01:18:13 PM »
Exactly. With the adapter the carb stuck out the hood. Now a boss 429 scoop will clear with the air filter.
Jaime
top end toploader
Reply #3 on:
February 27, 2022, 01:22:41 PM »
To bad the mr gasket #1930 is no longer available, there only a half inch thick. I have a couple of those packed away in my stash. Nice job on the conversion.
lstanford
Newbie
Reply #4 on:
February 27, 2022, 06:09:56 PM »
I had Wilson Manifold modify my Dove manifold the same way. It was done about 12 years ago. Car ran great after the modification.
475fetoploader
Sr. Member
Reply #5 on:
February 27, 2022, 08:10:02 PM »
I think it’s a fine idea, Dominators are quite a thing. I’ve never switched to one, without gaining mph through the traps. I believe you executed the modification as good as anyone would have. I hope it does everything you are looking for.
1967 519 c.i. TKX 5 speed
bobb428
Full Member
Reply #6 on:
February 28, 2022, 12:12:46 AM »
Did the same thing to mine.
My 68 1094
by
Bob Smith
, on Flickr
gdaddy01
Reply #7 on:
February 28, 2022, 05:23:39 PM »
nice engine, I going to guess that you do not have to worry about your radiator hose coming off. nice detail on the car.
FE Technical Forum
