Author Topic: 4500 flange Dove intake  (Read 4595 times)
fastback 427
« on: February 27, 2022, 12:43:44 PM »
Since Dove only made a few dominator flange intakes we welded this one up. Had a summit adapter milled 3/4" and the intake milled 3/4" then welded them. Smoothed out the plenum with a air powered mini belt sander and various carbides.
Wondering your thoughts on performance?
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
Re: 4500 flange Dove intake
« Reply #1 on: February 27, 2022, 01:11:57 PM »
Nice work, I'm sure it will be just fine. I'm guessing you were fighting for hood clearance  and not able to use a HVH adapter.
fastback 427
« Reply #2 on: February 27, 2022, 01:18:13 PM »
Exactly. With the adapter the carb stuck out the hood. Now a boss 429 scoop will clear with the air filter.
Jaime
top end toploader
« Reply #3 on: February 27, 2022, 01:22:41 PM »
To bad the mr gasket #1930 is no longer available,  there only a half inch thick. I have a couple of those packed away in my stash. Nice job on the conversion.
lstanford
« Reply #4 on: February 27, 2022, 06:09:56 PM »
I had Wilson Manifold modify my Dove manifold the same way. It was done about 12 years ago. Car ran great after the modification.
475fetoploader
« Reply #5 on: February 27, 2022, 08:10:02 PM »
I think it’s a fine idea,  Dominators are quite a thing.  I’ve never switched to one, without gaining mph through the traps. I believe you executed the modification as good as anyone would have. I hope it does everything you are looking for.
1967  519 c.i.  TKX 5 speed
bobb428
« Reply #6 on: February 28, 2022, 12:12:46 AM »
Did the same thing to mine.
My 68 1094 by Bob Smith, on Flickr
gdaddy01
« Reply #7 on: February 28, 2022, 05:23:39 PM »
nice engine, I going to guess that you do not have to worry about your radiator hose coming off. nice detail on the car.
