Author Topic: Lykins Motorsports 427 High Riser  (Read 16725 times)
« on: September 18, 2021, 04:26:06 PM »
Performance Summary:
      Cubic Inches:  427             Dyno brand:  Stuska
      Power Adder:                    Where dynoed:  Dale Meers Racing Engines, Buffalo, KY
      Peak Horsepower:  549 @ 6000
      Peak Torque:  523 @ 5000
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Factory 427 center oiler, 4.240"
   Crankshaft brand, cast or forged, stroke, journal size:  FoMoCo 427 crank, .010"/.010"
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Molnar Ford FE 6.490"
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Diamond 2618, 1.780" compression height, 5cc dome, 12.3:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Calico coated FM main bearings, Calico coated King rod bearings, Durabond cam bearings
   Piston rings brand, size, other notes:  Total Seal, 1mm/1mm/2mm
   Oil Pump, pickup, and drive:  Melling M57HV, Canton pickup, ARP drive
   Oil pan, windage tray, oil filter adapter:  Canton rear sump, aftermarket oil filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Lykins Motorsports solid flat tappet
   Lifters brand, type:  Trend tool steel
   Timing chain and timing cover: Ford Racing and factory timing cover
   Cylinder heads brand, material, port and chamber information:  Ported factory high riser
   Flow bench used, location:  Not flowed
   Intake valve brand, head size, stem size:  Custom 2.190", 11/32" stem SI stainless
   Exhaust valve brand, head size, stem size:  Custom 1.76", 11/32" stem SI stainless
   Valve springs brand, part number, specs:  TFS/PAC, 120/365
   Retainers and locks brand, part number, specs:  Crane steel retainer, Crower valve lock, Manley seals
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  T&D street, HR, 1.76:1
   Rocker shafts and stands, brand, material:  T&D
   Pushrods brand, type, length:  Trend, 5/16, .080", 9.375"/9.350"
   Valve covers, brand, type:   Chrome Baldy
   Distributor brand, advance curve information:  MSD
   Harmonic balancer brand:   Powerbond
   Water pump brand, type (mechanical or electric):   CVR electric
   Intake manifold brand, material, porting information:  Ported factory single carb
   Carburetor(s) brand, type:  (1) Custom Quick Fuel BDQ-850
   Exhaust manifolds or headers brand, type:  Dyno headers, 2" tubes
Katz427
Re: Lykins Motorsports 427 High Riser
« Reply #1 on: September 18, 2021, 05:42:52 PM »
Watched your videos of assembly of this one and 428. They turned out nice!
« Reply #2 on: September 22, 2021, 02:20:19 PM »
Nice Brent where the cam specs in the ballpark of a stock High  rise cam. I dont know if the specs are confidential.
« Reply #3 on: September 22, 2021, 06:06:38 PM »
What are factory cam specs?
HR427
« Reply #4 on: January 06, 2022, 07:30:58 AM »
Nice build!
Do you think the factory 2x4 and carbs would yield more power?
« Reply #5 on: January 06, 2022, 10:47:36 AM »
That's a bit better than the Ford advertised 425hp  ;D
We have a dyno sheet on a high riser that was intended as a 100% stock rebuild, made 530hp with the 2x4 intake.
HR427
« Reply #6 on: January 06, 2022, 05:25:36 PM »
Which cam Brunson?
« Last Edit: January 06, 2022, 05:39:56 PM by HR427 »
« Reply #7 on: January 06, 2022, 05:47:32 PM »
Nice build!
Absolutely.
Or Jay's intake adapter with a big fat single plane.
« Reply #8 on: January 07, 2022, 11:39:26 AM »
Which cam Brunson?
I'll look for you this weekend. If I remember right it was a comp custom grind trying to mimick the factory cam. Not quite an exact match but close.
dozz302
« Reply #9 on: April 26, 2022, 09:43:41 PM »
Which cam was this engine running?
HR427
« Reply #10 on: July 07, 2022, 06:54:37 AM »
Well, dynod my Nhra stocker blueprinted high riser.  Untouched ports in the heads and intake support power well in into the 600s.....solid flat tappet cam with .524 lift.
« Reply #11 on: July 07, 2022, 07:03:28 AM »
Any specs on that one as an NHRA stocker vs a Ford delivered version?
HR427
« Reply #12 on: July 12, 2022, 01:33:19 PM »
[/quote]
[/quote]
Filled block, thin rings, bbc rod journals, 20+ more duration, better valve springs, valve job, .013+ stroke, compression is just a tad over 15, 3 step headers......
« Reply #13 on: July 13, 2022, 07:43:17 AM »
Certainly makes sense.   I bet that is a stout machine!
Almost enough compression to run on diesel fuel ;)
dozz302
« Reply #14 on: September 25, 2022, 10:12:48 PM »
Who makes rings for a 4.24 bore?? I thought the closest was a .017 over which would be a 4.25 bore.
