Author Topic: Bolt in front coilover's  (Read 10104 times)
Jb427
« on: September 08, 2021, 12:02:09 PM »
any one used bolt in replacements for std type shock spring set up for a bolt in adjustable coilover? no mods bolt in type
Re: Bolt in front coilover's
« Reply #2 on: September 08, 2021, 02:32:53 PM »
Thats a pretty nice setup. Does anyone know what a stock big block spring rate is. Thats gotta save 20lbs a side.
gregaba
« Reply #3 on: September 08, 2021, 03:09:40 PM »
I installed the Aldan setup on my 71 Ranchero. Went in great and if I remember the coil rate is 400 lbs for the big block.
I liked them so much I ordered a set for my 63 Galaxie.
Greg
« Reply #4 on: September 08, 2021, 04:54:13 PM »
The spring dampening has multiple settings I think the add says. Is there a 90/10 for the front
JamesonRacing
« Reply #5 on: September 09, 2021, 06:57:19 AM »
I've installed this kit in my 66 Fairlane and my 65 Falcon.
Well made, easy to install.
https://streetortrack.com/suspension/front-suspension/coilover-system/street-or-track-mustang-front-bilstein-coilover-system
« Reply #6 on: September 09, 2021, 09:44:35 AM »
With double adjustable shocks you'd have to dial in the equivalent for extension and rebound.  I'd imagine Aldan or the shock mfg could get you a close dial in to start.
I like the Aldan setup.  Wonder how the "450 in/lb" rate works in place of my Moroso Trick springs that are 242 in/lbs.  They may have other spring rates available.
pbf777
« Reply #7 on: September 09, 2021, 09:45:24 AM »
     In my opinion, the first set-up referenced is asking a lot of the top three bolts & area about the fastening in the shock-tower (might want to add some additional steel weldment reinforcement here)   ;)  ; and the second looks a lot like a Rube-Goldberg endeavor to make a wrong coil-over fit in an application it doesn't belong (and accepting an overly compact component, when if taking advantage of the available distance something better could be had just seems wrong)!   :o
     But it's all bright & shinny; and it sells!   ::)
     Scott.
gregaba
« Reply #8 on: September 09, 2021, 09:52:39 AM »
The Alden system comes with a thick top plate and new bolts for the top of the shop tower.
Seems to be much stronger then stock.
Greg
hbstang
« Reply #9 on: September 09, 2021, 01:31:35 PM »
these a pretty nice as well,and have a tapered spring.they are viking double adjustable shocks and springs.bolt in for fairlane.i have a set on my 64 fairlane,but have not driven the car yet!they are nice quality parts.
https://www.ebay.com/itm/334005733960?hash=item4dc44b0a48:g:MWcAAOSwowtgaa4U
« Last Edit: September 09, 2021, 01:33:55 PM by hbstang »
Jb427
« Reply #10 on: September 09, 2021, 02:06:26 PM »
gregaba
« Reply #11 on: September 09, 2021, 03:11:31 PM »
My setup is basicly the same with the same spring rate. If ypu think about an FE will weigh in above 500 pounds.
I know with my 71 with a 429 they work fine.
Not sure but I think the 429 is lighter then the FE.
Greg
Jb427
« Reply #12 on: September 09, 2021, 03:45:59 PM »
Greg
Yes i went from a stock 390 c6 to 482 bbm and toploader and mine droped almost 1 inch over what it was before
66FAIRLANE
  • Andy
« Reply #13 on: September 09, 2021, 05:59:05 PM »
Where the hell did the extra weight come from? Thought the new combo would be loaded with aluminium.
pbf777
« Reply #14 on: September 09, 2021, 07:34:57 PM »
     Not in O.E.M. production trim.  Believe me, the 385's are heavier!    ;)
     Scott.
