Author Topic: Carb Hesitation  (Read 2469 times)
Saltshaker
Carb Hesitation
« on: July 21, 2021, 06:39:37 PM »
Engine ran flawlessly in my old car but I needed to remove the 1” open spacer from the rpm intake and it now hesitates off the line. Would removing the spacer cause this and any suggestions for a cure?
Jon
« Last Edit: July 21, 2021, 08:49:31 PM by Saltshaker »
chilly460
Re: Carb Hesitation
« Reply #1 on: July 22, 2021, 07:15:53 AM »
Did you touch anything else at all?  I'd start simple with something I see all the time, is the accel pump arm(s) adjusted correctly?
Thumperbird
Re: Carb Hesitation
« Reply #2 on: July 22, 2021, 10:27:52 AM »
You said "in my old car"
Is it installed in a different vehicle now, if so, how much different is the weight and drive train?
Saltshaker
Re: Carb Hesitation
« Reply #3 on: July 22, 2021, 11:49:43 AM »
same wt, but this car has a automatic with a 1800-2200 converter
Jon
