Author Topic: 390 Stroker for FE Power Cylinder Heads  (Read 15188 times)
« on: June 24, 2021, 04:57:12 PM »
One of the things I've wanted to do with my cylinder head package is to put it on a fairly standard 390 stroker engine, and see how it performed.  I've had a little break in the action on the head project, because the aluminum foundry is really backed up and despite ordering castings for the intake adapters and heads in March and April, they have still not been poured, so I decided to get a head start on this project.  I have two 390 blocks here that I could choose from, so I decided to sonic test them and pick the best one.
One of the blocks is already .040" over; this is the block that was the basis of my 390 stroker engine, featured in my book.  I had set this engine on the stand and forgotten about it for the last 10 years, so a few days ago I pulled it all apart so I could check it.  Everything looked very good, which was encouraging after all the dyno abuse that this block saw.  But when I sonic tested it, there were a few holes that looked a little thin to me.  The sonic test results are below:
In particular, the front side of cylinders 2 through 4, and the back side of cylinders 6 and 7, looked a little thin.  I was going to bore this block another .020", and my arbitrary requirements for minimum cylinder wall thickness is 0.100" after boring for non-thrust surfaces, and 0.125" after boring for thrust surfaces, hopefully with more thickness on the major thrust side (shown in red in the picture) than on the minor thrust side (shown in yellow).  Several cylinders on this block weren't going to meet these requirements.  Now, of course this block took a bunch of abuse at 500+ HP on my dyno, and as-is cylinder 4 is below my requirements, and there weren't any problems, so maybe I shouldn't be too concerned.  But I decided to check the other block out and see if it looked better.
Turned out it did; the sonic check data for that block is below:
This block is currently standard bore, which helps of course, and the areas of concern were the minor thrust sides on cylinders 5, 6, and 7.  Again I was figuring to bore this block .020" (0.010" on each side), and I'd be below my arbitrary requirements on the minor thrust side of these cylinders.  However, I'm a big believer in sleeves, since they are actually better material than the block material itself, so I think I will sleeve 5 and 7, and leave 6 as-is, to make this block as robust as possible.
Since I was going to abuse this engine somewhat, I had previously decided to run a girdle.  I had never used one and wanted to try one out, and there had been one appearing on ebay that I thought looked pretty good.  I was planning to pin the rail of the girdle to the pan rail, so that it couldn't move, and then machine some precision spacers to go between the girdle and the main caps.  I was going to bolt it all together, take the block in for an align-hone, and then if the caps had to be cut a few thousandths, compensate with some shim stock between the caps and the girdle.
This approach went out the window though, when I went back on ebay and the girdle I was looking at was no longer listed.  However, there was a set of Pro Gram caps listed.  Well, that was going to be a much bigger machining project to make them fit, but I didn't want to wait for the girdle because I have some time now, and won't have it later.  So, I went ahead and bought the set of Pro Gram caps.  I also purchased an ARP main stud kit to use with the caps.  Pictures of the parts are below:
So right off the bat I have more into this project (about $500) than I would have had with the girdle, and I had some serious machine work on the block to do.  When the parts arrived the stud kit looked fine, but unfortunately the cross bolts and washers were not included with the caps, as they should have been.  I contacted the seller and they are supposedly on the way to me now, but to get going on this project I dug up some grade 8 bolts that I could use for the crossbolts.
The instructions that came with the caps tell you how to machine the block to make them fit.  One thing I found a little strange was that the instructions were from a company called Billet Speedworks; no mention of Pro Gram Engineering anywhere.  Nevertheless, I hoisted the block up onto my big CNC machine, and cut the sides for clearance to the ears of the caps.  The first picture below shows the block on the machine, and the second picture shows one side of the block after the machining operation is complete:
One thing I found helpful is the location of the two holes on the right side of the FE block, as shown in the photo above.  These holes are used to bolt the block to the cradle during Ford's assembly operation and were in the perfect spot to line up with the ears of the caps once they were installed.  I was able to install the caps temporarily at this point (see the picture below), and then use those holes to mark the caps for the crossbolt locations on two of the caps.  This also gave me a reference to the pan rail, so that I could transfer the dimensions to the middle cap, and the left side of the block.
After marking the caps, I transferred them to the smaller CNC machine.  I measured the two marks that I'd made with the caps installed and duplicated those hole positions on all three caps, both ends.  Then I drilled and tapped the ends for 3/8-16 thread.  I also drilled and tapped a 5/16-18 hole in the center of each cap, because I found them difficult to remove from the block after the first test install.  With the tapped hole, a slide hammer can be used to remove them, similar to what is required with some of the aftermarket blocks.  A picture of the caps after the last machining operation is shown below:
While I was at it, I also pulled the stock #5 main cap out and counterbored it 0.275", to allow the nuts for the ARP studs to sit below the pan rail.  I was happy to see that the two studs for the rear cap were shorter, so the studs themselves didn't extend up beyond the pan rail, but left as is the nuts and washers would have.  Counterboring the cap was pretty easy, compared to all the other machining operations I had to do for this project.
I was hoping that I'd be able to drill the holes in the block for the crossbolts without having to put the block back on the CNC, but that didn't work out.  I tried to do it with my drill press but the travel of the drill press didn't reach all the way down to the block, as it was sitting on the engine stand.  I also tried a hand drill, using a 1-2-3 block as a fixture to ensure that the hole went in square with the side of the block, but I couldn't easily get a clean hole; the drill tended to drift around too much.  So, in the end I gave up and put the block back on the CNC machine to drill and spot face the cross bolt holes, as shown in the photo below:
After flipping the block over to get to the holes on the other side, finally I was able to pull the block off the machine and install the caps and crossbolts:
And of course, I'm not done yet, because the caps are undersized, and so now the block has to be align bored and then align honed in order to get the bearing clearances right.  Depending on how much that costs, I think I'll probably have between $800 and $900 in this project, plus all the machine work I did myself.
Anyone with a Bridgeport or other vertical mill could do what I did to this block, but it is a painstaking operation and takes quite a bit of time; I think I had 8-9 hours in the whole project.  If you have to pay to get the machine work done that I did, seems like you'd be better off just getting an aftermarket 427 block.  I think adding a girdle would be much easier and cheaper, and next time I do something like this that will be my preferred approach.  But for now, I think I've got a block that I'm comfortable with up to the 700 HP level.  I'll add more information to this post as the engine goes together, but it will be a while; pistons are 8-10 weeks out...
« Last Edit: June 24, 2021, 05:08:39 PM by jayb »
Re: 390 Stroker for FE Power Cylinder Heads
« Reply #1 on: June 24, 2021, 06:33:21 PM »
Geez!  I'm having a bit of size envy.
Today I was CNC machining some 1 inch pieces of brass and aluminum on the Mini Mill.  I felt pretty good about my day until I logged on here...
« Reply #2 on: June 24, 2021, 08:45:43 PM »
With all the work and effort you've put into it, and considering its intended purpose, had you considered pinning the caps? I know the crossbolts will help with any cap movement, but pinning adds an extra ounce of prevention. I think the BBM blocks are pinned also. Besides, it's easy to suggest more work when you're not the one doing it..lol
« Reply #3 on: June 24, 2021, 09:32:30 PM »
I hadn't thought about doing that Doug, that would be a nice feature to add to this setup.  But I think it would be difficult to get the pins in the block and the holes in the cap machined so that they lined up perfectly.  These caps are a really tight fit in the block registers, so laterally there would be no room for error in the machining operations.  Getting them in exactly the right spot, both laterally and fore and aft, seems like it would be tough.  I'd be particularly concerned about #3, since the thrust bearing flanges have to line up just right.
I would guess that the aftermarket blocks that use alignment pins probably install the caps in a semi-finished state, then line bore the main saddle and also machine the surfaces for the thrust bearing with the caps assembled and torqued.  That way everything is perfectly lined up.  Adding caps with pins to a block where the main saddle has already been machined is a more difficult problem, I think...
« Last Edit: June 24, 2021, 10:38:48 PM by jayb »
« Reply #4 on: June 24, 2021, 10:21:45 PM »
Nice work Jay are these the things you do when your bored :)
« Reply #5 on: June 25, 2021, 12:43:39 AM »
When asking the question, I was picturing how it might be done and was thinking the same as you. But machinists, which I am not, always seem to find innovative and original ideas on how to do things. I actually thought the thrust might be the easiest, since you have two perfectly machined surfaces at right angles to determine measurements from. Regardless, with the studs and crossbolts, it's probably overkill on anything short of a full out build.
« Reply #6 on: June 25, 2021, 05:54:38 AM »
I'd much rather have the cross bolted caps than a girdle.   A girdle is a machining nightmare.  Pan rails have to be zero'd and surfaced, caps have to be cut down, surfaced, etc.  Unless you build some "preload" into the system, you will still have room for the caps to squirm, even if a very finite amount.
Obviously, on an FE, the pan rail holding the girdle down is an added bonus above a SBF/BBF girdle, but if the caps wanted to move away from the block bad enough, I think they still would.  On SBF's, I've seen the blocks split in half with the girdle just holding the main caps together.
You see aftermarket blocks with cross bolted caps.  You never see aftermarket blocks come with girdles.
You need to provide this service, Jay.  Not a lot of guys like to do it.  Lots of labor involved.
« Reply #7 on: June 25, 2021, 06:59:14 AM »
I am no machinist or CnC programmer, but are the main bolts and pan rails consistent enough to make this a automatic CnC operation?
6667fan
  • Every Second Counts
« Reply #8 on: June 25, 2021, 07:34:55 AM »
Jay, I like your sonic read out form. Would a template be available? Proprietary?
It is something I would run copies of for my builder to use.
Do you have a hoist system in that shop or are you humping those FE blocks into the machines yourself?
Thanks for sharing the step by step on that mission.
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
« Reply #9 on: June 25, 2021, 08:44:28 AM »
Having done this once, I do NOT want to do it again.  It isn't like you can just install the block on the CNC and go.  To begin with, you need to indicate on each main cap register to make sure the block is parallel with the X axis of the mill, and then lock the block down so that it doesn't move during the machining operations.  Locking it down is a problem because there really isn't any flat surface that you can rely on to fix the block in the Y axis.  I ended up putting bolts in two of the water pump holes and two of the bellhousing bolt holes, rotating them so that one side of the bolt was vertical, then bolting some blocks to the mill table to contact the vertical surface of the bolts.  Not a real solid arrangement.  Then I had to thread in more bolts to use for holding the block down on the table.  It would be one thing if I could somehow come up with a fixture that every block would sit into and that I could indicate off of, but there's just no way that every block would line up the same way.
I've never done a girdle, but comparatively speaking the machining operations would be simple.  Spot facing the caps is easy.  I don't think that squaring the pan rail is even necessary, provided that you can accurately measure the distance between the girdle and the top of the main caps, but even if you did have to do it, it wouldn't be that hard.  The question mark to me about a girdle is how much additional strength would it offer, but I figure it would have to help a lot.  We're trying to prevent twisting of the #2 and #4 caps, to avoid breaking the block, and the girdle ought to be pretty good for that.  It wouldn't be as good as cross bolting, but for the power levels you're trying to get out of a 390 block, it ought to be plenty adequate.
Next time I do one of these, assuming the girdles are available, that's the way I'll go...
« Reply #10 on: June 25, 2021, 08:50:57 AM »
Ross, I don't have any data to support this statement, but I'd bet a lot of money that the blocks are nowhere near consistent enough to fixture the same.  I think it's a good bet that the main cap registers are all going to be parallel and aligned with each other, but relative to an outside surface of the block where it needs to be fixtured?  No way.
Once the block is aligned properly and fixtured so that it won't move, then an automatic CNC operation will work, and in fact I wrote a program to make the cuts.  But getting the block to the point where it can be machined is the challenge...
« Reply #11 on: June 25, 2021, 08:54:02 AM »
I just use an Excel spreadsheet for the sonic check data, nothing proprietary about it.  PM me with your address and I'll mail you a blank copy.
I do have a hoist to move heavy items onto the mill, the fixture for machining my intake adapters is over 150 pounds, so I use the hoist primarily for taking that on and off the machine.  Worked fine for the block, too...
« Reply #12 on: June 25, 2021, 09:09:35 AM »
You'd be surprised on how far the pan rails are out on factory stuff.   We did one block with the girdle and decided to never do one again.  You end up chasing your tail in circles trying to get everything spotted.
« Reply #13 on: June 25, 2021, 09:34:41 AM »
So, what's the issue?  Are they not flat, or are they not parallel to the cap registers, or?
« Reply #14 on: June 25, 2021, 09:39:56 AM »
Yep.
