FE Technical Forum
FE Engine Dyno Results
352/360 dyno results
Topic: 352/360 dyno results (Read 5856 times)
Royce
May 31, 2021, 10:34:07 AM »
Not as good as I had hoped
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
Kaase Boss 547. 840 HP 698 Torque pump gas
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
Re: 352/360 dyno results
Reply #1 on:
May 31, 2021, 12:27:23 PM »
With just the hp increase that the carb gives, it makes you wonder what the 390 manifold would have done.
gdaddy01
Reply #2 on:
June 04, 2021, 09:35:02 PM »
is that a stock waterpump , looks like a long pulley shaft . I like the looks of the engine . what rpm are the shortie manifolds good for before headers would be better ?
Royce
Reply #3 on:
June 07, 2021, 08:15:27 AM »
Yes stock water pump for a 60 FE...Just guessing but I would suspect headers would start to eclipse the manifolds at about 4000 rpm
1992 BMW V-12 5.0
gdaddy01
Reply #4 on:
July 07, 2021, 07:12:15 PM »
thanks , was wondering about maybe running the short manifolds instead of headers on a street truck , 1949 f 1 with 1966 t- bird 390 engine
FE Technical Forum
