Author Topic: Does a crankshaft actually sag if stored on it's side...  (Read 16195 times)
philminotti
« on: May 16, 2021, 03:08:47 PM »
Or is that an old wives tale?  If so, is it months, years, or decades?
Phil
GerryP
Re: Does a crankshaft actually sag if stored on it's side...
« Reply #1 on: May 16, 2021, 03:19:03 PM »
Theoretically true.  If you consider that molecules not at absolute zero are free to move around and that seemingly solid objects are always fluid, then a crank can sag.  But you have entropy too, so it's possible that you could lay it down one day and come back the next day and it's a dust pile of Fe.
I always store things as safely as possible.  I've never seen a crank fall off the floor or fall over while laying on its side.
philminotti
« Reply #2 on: May 16, 2021, 03:24:52 PM »
I hear you on the safety issue... It's currently laying on my bench...but my wife and children have been known to repurpose my tools from time to time, and I would absolutely lose my shit if I walked into my shop to see it fallen over if I had it standing up!
« Reply #3 on: May 16, 2021, 03:29:31 PM »
You can put back in its box, it will be safe there.   It's ok to store them on their side.   Think of how many crankshafts are stored in their boxes with only the nose and hindend supported.
ch3no2
« Reply #4 on: May 16, 2021, 04:47:34 PM »
I hang'em.
wowens
« Reply #5 on: May 16, 2021, 05:12:45 PM »
Could machine shops standing cranks on end due to lack of storage space and not because cranks bend be the daddy of this idea ?
Woody
GerryP
« Reply #6 on: May 16, 2021, 05:19:54 PM »
Yes.  You can go to outer space vertical.  Horzontal, just to the end of your garage.
« Reply #7 on: May 16, 2021, 07:58:25 PM »
If you live on Long Island and get your crank cut at any shop it goes to one guy. He says he does about 80 percent of the cranks from the engine shops. We were talking about this subject and he said that laying a crank on its side will never bend or warp a crank.
« Reply #8 on: May 16, 2021, 08:15:39 PM »
I hang'em.
Careful, they might stretch doing that!  ;D
475fetoploader
« Reply #9 on: May 16, 2021, 11:59:07 PM »
After I install an engine in a car, I always store the car vertically, if I don’t intend to drive it for an extended period.
1967  519 c.i.  TKX 5 speed
chilly460
« Reply #10 on: May 17, 2021, 06:35:15 AM »
This one always seemed silly to me.  If you stand it on end, are the bending forces also still not at work, trying to pinch the counterweights together?  The crank is more supported on it's side than standing, the way I see it.
« Reply #11 on: May 17, 2021, 06:46:21 AM »
I agree completely, silly to think it cannot support it's own weight, especially cast iron
 8) Got a kick out of both of these
« Reply #12 on: May 17, 2021, 07:19:59 AM »
Considering all new cranks that I have seen, come in boxes, with the crank horizontal, I would doubt it is a real issue. I CAN say, that if you have a bunch of FE cranks standing on the floor, upright, and one tips over, causing a Domino effect, chances are very good  that some damage will occur!
« Reply #13 on: May 17, 2021, 07:33:31 AM »
It usually happens when you are trying to get the 3rd one back and in a hurry :)
« Reply #14 on: May 17, 2021, 07:43:11 AM »
Yes.  You can go to outer space vertical.  Horizontal, just to the end of your garage.
You actually go to outer space horizontally - the vertical part of the trip is comparatively short
As for the crankshafts - Doug's "stretch" comment is pretty awesome...
