Author Topic: Does a crankshaft actually sag if stored on it's side...  (Read 16197 times)
Dumpling
Re: Does a crankshaft actually sag if stored on it's side...
« Reply #15 on: May 17, 2021, 11:03:05 AM »
I like to bury my cranks in the lawn. The dirt conforms to its shape and supports it evenly along its length. The grass seems to like the iron in the soil as well.
« Reply #16 on: May 17, 2021, 11:58:21 AM »
Considering all new cranks that I have seen, come in boxes, with the crank horizontal, I would doubt it is a real issue. I CAN say, that if you have a bunch of FE cranks standing on the floor, upright, and one tips over, causing a Domino effect, chances are very good  that some damage will occur!
It usually happens when you are trying to get the 3rd one back and in a hurry :)
And usually when you are wearing running shoes or sandals!
wayne
« Reply #17 on: May 17, 2021, 02:10:03 PM »
Just had one done that was on it side for 35 years it was ok Harts in ohio is super if you need a shop.
C8OZ
« Reply #18 on: May 17, 2021, 03:22:06 PM »
Imagine how noodly your cam must be when you go for the last journal holding it up with just the bolt.  :'(
Lowrider
« Reply #19 on: May 18, 2021, 07:45:35 AM »
While we're talking myths, I heard years ago that storing a block without the main caps installed would cause the block to "stretch" at the main journals. I put them back on to keep from losing/misplacing them. Nothing more frustrating than to see an ad for a block for sale without the main caps. I can see a set of main caps for sale from a "lunched" block but not the other way around.
gt350hr
« Reply #20 on: May 18, 2021, 09:34:14 AM »
   I just talked to Scat and they laughed. NO problem at ALL to lay a crank down. Callies already told me the same thing.
   Randy
C6AE
« Reply #21 on: May 18, 2021, 01:59:40 PM »
I thought that only worked with 3-3/4" flathead cranks in the garden.
They next owner is going to have to buy new tines for his tiller...
RustyCrankshaft
« Reply #22 on: May 18, 2021, 11:20:57 PM »
I've never personally seen a crank out of a typical gas V8 have an issue from being laid on down for storage, but I have seen a diesel crank have an issue. Big weight difference tho.
« Reply #23 on: May 19, 2021, 12:40:45 PM »
with a name like rusty crankshaft you should know all about it. ;)
RustyCrankshaft
« Reply #24 on: May 19, 2021, 11:07:46 PM »
Well, after you bury the crank in the back yard for storage and all.......
If you don't want to do that much digging they also make great mailbox posts...the neighbors Honda doesn't even budge them!
The cranks we had bend (it was repeatable, over the years I worked at that outfit I saw 3 do it) were out of big Cummins V engines. Had them straightened and cleaned up and went back together. They're heavy enough that when they turn them they support the center of the cranks with 2 air cylinders rigged from the ceiling to keep them from flexing and causing the journal to taper.
Dumpling
« Reply #25 on: May 20, 2021, 06:55:35 PM »
Not storage so much as laying to rest....
« Reply #26 on: May 21, 2021, 06:42:08 AM »
LOL
Scrap is really high right now ($240-$290 ton, depending, in my area), so you might want to consider digging them up and making a small fortune. :)
JC-427Stroker
« Reply #27 on: May 23, 2021, 11:13:29 AM »
After I install an engine in a car, I always store the car vertically, if I don’t intend to drive it for an extended period.
Where's the "Like" button ?
« Reply #28 on: May 23, 2021, 07:57:10 PM »
I have seen them hanging from a rack like wind chimes. Mine all stand up but that is a space issue. I have twelve of them standing up. Anyone need five 3 1/2" stroke 352/360 cranks?
gregaba
« Reply #29 on: May 24, 2021, 10:44:07 AM »
I think this rumor goes back to the 40's and 50's when there were a lot of stright 8 and 6 engines.
I remember going to dad's machine shop with him and they had all the cranks hanging in racks.
They all so had all the heads stacked on end.
Greg
