Author Topic: missmatched ports  (Read 5282 times)
motorheadted
missmatched ports
« on: April 30, 2021, 10:55:02 AM »
My Weber intake manifold ports were port matched to the taller 428 intake sizes before i got it some years ago, and I ported my E-bock heads to match the intake on the 1st re-build.
I am now rebuilding it again with a different set of  E-boks with the mid-rise int port sizes which are less tall than  the 428 size, closer to the mid rise 427 size (engine is 427)  and I was wondering if anyone here had ever made a port smaller using an epoxy  ( JB Weld) as opposed to welding build-up & re-grind to size . ??
Ted .
bill_396
Re: missmatched ports
« Reply #1 on: April 30, 2021, 01:01:44 PM »
I believe they make specialized epoxy based products just for that purpose. My intake has had the floor of the port opening brought up about 1/4" if I'm remembering correctly.
« Reply #2 on: April 30, 2021, 01:43:39 PM »
Do the port roofs line up?
« Reply #3 on: April 30, 2021, 03:58:14 PM »
If the roof and sides match well, then I wouldn't worry about it.  Every time I blend the floor of a MR head to the CJ port floor, they lose flow on the flow bench.  Joe-JDC
motorheadted
« Reply #4 on: April 30, 2021, 04:34:21 PM »
All good info, Thanks Guys !!
« Reply #5 on: May 04, 2021, 10:03:26 AM »
NOT JB WELD
Use Splash Zone Compound - found usually at boat repair stores.  Works even with methanol (for a while LOL).  It's what is typically used to re-shape ports, stick port tongues in 351C 4V heads, re-shape ports in billet Jr Dragster engines, etc.
Also same - if the roof and sides line up well enough, run it.
motorheadted
« Reply #6 on: May 04, 2021, 04:13:55 PM »
i've found a couple of products  that would work; An A-B type sold by Moroso and Edelbrock and a Devcon product.
 However, based on Joe-JDC and Brents experiences, I'll try doing without trying to match the floor. I have a previous dyno sheet to compare the mismatch intake affect on performance
The roof and sides are OK.
Ted
bill_396
« Reply #7 on: May 06, 2021, 12:42:39 PM »
Just to be clear, do you have dam or a waterfall condition?  Waterfall okay, dam, don't think so.
« Reply #8 on: May 06, 2021, 06:01:39 PM »
Dam on the bottom doesn’t hurt, bulk of the flow is running along the long side (roof and sides)
6667fan
  • Every Second Counts
« Reply #9 on: May 08, 2021, 06:39:01 AM »
Could be worse. You could be trying to stick an intake with medium riser ports on these heads.
That is a Mr. Gasket 202 A medium riser gasket laying there.
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
« Reply #10 on: May 08, 2021, 07:03:24 AM »
You need some Cometic intake gaskets and then trim if necessary.
6667fan
« Reply #11 on: May 08, 2021, 09:11:59 AM »
Exactly.
Blair is hooking me up with something that is .060 thick and no ports are cut out, just water passage and bolt holes. I still have to be mindful of how close to Barry’s port I try to get size wise. The limiting factor is my Dove TW does not have abundant material around every port.
I realize I don’t need to match them from a flow standpoint. I’m after a better seal than I had with the 1247-S3 that were last on engine.
JB
67 Fairlane 500
482 cid 700/617
