FE Power Forums => Non-FE Discussion Forum => Topic started by: chris401 on August 22, 2020, 02:33:36 PM
Title: Flathead I6 226 H Series Camshaft Timing. Odd
Post by: chris401 on August 22, 2020, 02:33:36 PM
It is an 8N Funk conversion. Forget the timing marks for reference. It has a stock 8N flat 4 crank pulley on it. I am doing this based of what I know about the internal combustion engine, or thought I did.
With the throttle closed warm static compression readings were 106-119 psi. Next I performed a cylinder leak down test. For you guys who have dealt with these you know the sparkplug is over the valves so finding TDC with a screw driver won't work. Limited over head room due to the gas tank location. The crank key way is at 6 o'clock with #1 TDC but the crank pulley is trapped by the axle pin housing.
Now to the question at hand.
Is it characteristic for an Industrial Flathead Ford to begin to open the exhaust valve at the top of the compression stroke? Across the cylinders both valves were not closed until I rolled the engine backwards by hand. At this point it was on the front side of piston TDC. When rolling backwards into the compression stroke could gain up to 40/45% moderate cylinder pressure. At that point the fan belt would slip on the pulley bottoming the piston until the intake valve opened.
In a nutshell it feels like the intake valve is closing with the piston at BDC and exhaust opening about 10° before piston TDC. I know this thing was rebuilt by Fred Jones in 1965. Other than milling the head was he known for any cam wizardry like this?
I looked online to see if the rod journals were offset with the beam but I can't tell. Once I rebuilt the (non Load-O-Matic) carb, put in Autolite 216's and timed the LOM by ear it started of the 1-2nd hit. Seems to run fairly strong. Looking forward to testing the hours to gallon with the new distributor. If I pulled the backhoe off and ran a square bailer it would be a better test of power.
EDIT: The Ford Industrial engine manual shows a press on and a bolt on cam gear. "IF" the cam gear did slip 75° back the exhaust valve would still be opening on a piston down stroke. Another straw to grab here is maybe this was before the days of overlap.
Title: Re: Flathead I6 226 H Series Camshaft Timing. Odd
Post by: My427stang on August 22, 2020, 02:52:04 PM
When compression ends, the power stroke starts, not the exhaust, so the answer is "not and have it run" it would just backfire out of the exhaust
Sounds to me like it has some sort of cam timing issue, very simplified below, things of course overlap
- suck (piston traveling down, intake valve open)
- squeeze (piston traveling up, no valves open)
- bang (piston traveling down, no valves open)
- blow (piston traveling up, exhaust valve open)
Post by: chris401 on August 22, 2020, 03:08:11 PM
You have it right. Been on the payroll as heavy line tech for about 20 years, thus the seemingly odd question above. Personally have not been deeper than a carburetor on any Flathead. I found one reference with a tractor I6 conversion engine exhaust valve open a 9° before TDC, the comment to that post was it's normal. The poster had his fresh rebuilt engine on a stand before the head was installed. Piston up valve cracked open. It could be my valve is on rock? I hope an old Flathead hand see's this one and explains something the rest of us don't know.
Post by: My427stang on August 22, 2020, 03:12:49 PM
Honest question, not being silly, but you aren't looking at the intake lobe by accident are you?  Intake would open just before TDC, exactly where depends on cam design
Post by: chris401 on August 22, 2020, 03:16:16 PM
Air passing through exhaust or carb. My post had to be very wordy to cover the whole scenario. All of the information I have at this point is buried in the primary post.
Post by: My427stang on August 22, 2020, 03:35:13 PM
I read it the first time, I wouldn't have commented.  As you pointed out. it doesn't make sense to open at the end of the compression/beginning of the power stroke. I am not exactly following your test procedures either and I went back and reread it a few times to try to follow
"Warm static compression" isn't a thing, if you are saying "warm cranking compression" and saying it actually runs, then it just isn't opening on the compression stroke, it  wouldn't run or build any compression.  If it doesn't run, then I'd ask you elaborate a little more
However, between old Jeeps and old Fords, not new to me, but I haven't ever done more than follow book procedures on those (and it's been a LONG time at that) not sure how anything, even a Briggs and Stratton can run if the exhaust opens on the early downstroke or near TDC
I may have books to see how to time it, especially if it is a 9N tractor engine, but haven't dusted those books off in a very long time
Post by: chris401 on August 22, 2020, 06:47:00 PM
Warm as in operating temperature. Static compression aka cranking compression. It is a coin toss to see who calls it what. I do have all the manuals for 8N and the Industrial 226. The Industrial manual calls for a bolt on and a slip on timing gear set. If I have slip in type maybe it slipped on the cam.
I just talked to a Flatbed builder. He didn't remember a whole lot about his last 226 build but he did give me an idea. The 4 cylinder tractor engines do have timing gears. If it is possible to interchange them with a six it is likely the cam gear timing marks are in different places. Makes sense but it still does not explain how a bee flies or in this case, How is this engine running?
Post by: chris401 on August 22, 2020, 07:07:28 PM
I have to pull the axle pin housing and hood off to pull the timing cover. It has been running fine for the last 8 months I have owned it so I hate to tear into it now. When the time comes I will report my findings. Hope I don't end up eating internet crow.
It is going to look a lot better when I get old propane cut hood off swapped out. Can't do that until I fabricate the carburetor bonnet and and intake duct to match the new oil bath air cleaner assembly. The paper element is only good for an hour on a dust day. The distributor is close to factory appearing.
Post by: frnkeore on August 23, 2020, 12:42:29 PM
I like your tractor! It sure is fully equiped.
For those that would like to know what the models are for the "N", 9N is 1939, 2N is '42, 8N, is '48. The 8N is easy to ID, because of the rear wheel bolt pattern of 8 on 6.
I don't have any N's but, I do have 3 each, 600 & 800 models that came right after them.
It looks like you have enough clearance, to check cam timing with a 1" travel indicator. They make short ones called Mighty Mag:
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2060353.m570.l1313&_nkw=mighty+mag&_sacat=0
The cam timing for the "H" engine @ .014 cam lift (valve clearance) is:
In 11/41 - Ex 48/10, 232/238 Duration and .350 lift.
.050 Duration = 205.2/211.4
107 LSA - In C/L 105 - 21 deg overlap
Post by: chris401 on August 23, 2020, 01:33:12 PM
Thank's for the camshaft map. Is it specified for a stationary industrial engine? I believe that is what this is. The intake carburetor pad does not have the slant of a passenger car. The Funk kit appears to be complete like would be typical of a dealer installed engine. The tractor is fully functional but just about everything is wore out. It will be an ongoing process.
Post by: frnkeore on August 23, 2020, 02:37:11 PM
I don't think that there would need to be a different, industrial cam.
In stock spec, the "H" gets it's max torque at 1200 rpm but, I don't have any info, on that engine, as a industrial.
The truck spec, is also, the same as the car but, for the 254, it has a different cam as, the TQ comes in on it, at 1400 rpm.
Post by: chris401 on August 23, 2020, 09:08:39 PM
If the H Series had ran production longer than 4 years I am sure more parts would have been available. No matter how long I look at the governor blank it will simply not turn into a tachometer drive. Should be easy enough for a machinist to make. Unless there were any used in boats or something else?
Post by: chris401 on August 23, 2020, 09:24:05 PM
Ross I'm sending a PM. I spotted a derelict 9N with what appeared to have an axillary transmission handle.  Can you swap a Sherman from a 9 to an 8 without changing any of the shafts?
Post by: chris401 on September 06, 2020, 10:08:04 AM
I've not made a mistake on this. A machinist said he remembers an odd profile on a marine 300 six. That is inline with a post I found on the ford barn. A poster rebuilt a Funk 6 and came across the same thing. All one if the members said that is normal. It would be interesting to know how this profile came about. Surely one of the builders here have dealt a marine 300.
Post by: My427stang on September 06, 2020, 10:19:14 AM
Not this one, land locked during most of my time.
Post by: chris401 on September 06, 2020, 08:07:44 PM
Didn't know you had any machine shop tooling, that is what I get for assuming. I don't consider myself a builder really. I put together parts someone else makes and hope they stay together and don't leak. I wanted to break into building with my last job. Had a good time learning the balance shop.
EDIT: Thank you for triggering a thought. The man who ran the balance shop built marine engines at one time. I think I will wake him up out of retirement.
Post by: chris401 on September 06, 2020, 08:43:29 PM
The geography of the timed components would be the reason this engine runs smooth and does not backfire. One day I'll tear off the front of the tractor to do something to it. At that point I'll map the camshaft and compare to frnkeore camshaft specs. Maybe it will help out the next guy who digs up one of these antiques.
frnkeore,
     Moved around some parts and come up with a complete hood. The old Ford has moved up from vandalized to just derelict.
Post by: frnkeore on September 07, 2020, 01:01:43 AM
A step at a time, Chris. A little here, a little there and some paint :)
Here's my 850 puller. 16.9 x 28 and 1600 lb of cast iron on the rear. 1160 lb on the outside and 440 lb on the inside. Still lots of little thing to do to it.
Post by: MeanGene on September 07, 2020, 01:45:26 PM
OK, I've watched all this fussing over cam timing- it has good compression, and you say it runs fine and smooth- so what's the problem? Run it! I also have a Funk 6 that appears to have all its original conversion parts. It has the stock 8N air cleaner, with a one piece tube and bonnet to the carb. Also has the stock Proofmeter (tach), driven by the stock 8N drive on the back of the 8N governor- very simple, just a fabbed bracket to remount the governor. When I fired mine up, it started instantly and ran very smooth, unfortunately the water pump leaked like a sieve, and I haven't had time to mess with it. It also has a backhoe on it, with a mini-tractor loader grafted on. When you start talking about a Sherman, you'd want to consider that it's running 115 hp through a trans and rearend that was designed around a 20-something hp engine. I also have a sweet '50 8N (1100 hrs!) with a Howard Reducer trans (and have the Howard Rotavator it was designed for) that was only to slow the tractor down enough to let the tiller work, not for plowing etc., not known for strength. I plowed snow with a front-distributor 8N with a Wagner step-through loader and the no sleeves and Mercury pistons upgrade when I was a kid in NY. I also have a nice 850 with a step-through, 16.9s with the pie weights, and the 800/801 series was always a horny small tractor, pulls hard
Post by: chris401 on September 08, 2020, 09:13:35 AM
My thoughts, my problem. My peer discussion turned into a help topic when I didn't ask for help. Looks like the guys who know these Flathead's don't fool around with these forums or are dead.
If you have a factory installed tachometers both of yours are April 1950 or newer. Different dash and steering box than 1948. Good job on keeping the Howard intact.
Post by: My427stang on September 08, 2020, 10:07:41 AM
Well it is an FE forum...  however seriously, I grew up working on these, and all kinds of open wheel stuff, and far more heavy equipment than the light stuff, but even the sharp guys didn't get into the detail we do with our hot rods.  The owners just needed them back to work, and it'd be a bonus if it didn't leak, but who cares if its on a dirt floor half the time, oil was cheap back then LOL.
I would venture to guess, anything more than knowing how to align timing marks, only happened if someone was building some sort of experiment.  Hell, we were the biggest Ford FE guys in the county and didn't hang a degree wheel on anything unless it was a racer.  Maybe that's the route, look for some crazy dude that ran one of the engines at Bonneville, there almost HAS to be someone, lots of inventive guys (and crazy)
That being said, I am interested, but I wouldn't even know where to get the info you are trying to figure out. If it's important to you, hang a degree wheel on it somehow, might take splitting it apart, but you'd know what it is.
Post by: MeanGene on September 08, 2020, 10:09:33 AM
I grew up working with many different tractors and equipment, my gramps had an International Harvester dealership, trucking and lime spreading, and several farms. We had the 8N, a couple genuine Jubilees, Fergie TO20s, IH 340, all with Wagner step-thru loaders for the lime spreading. He sold Farmall Ms, Hs, then the number series into the 06 series, we had a pair of Ms and a TD6 when I was little, then a pair of 706Ds and my uncles Deere 420 popper. Have had my own stuff, an M and Super M, Deere B and a 430W (that I traded for the 850/loader), a pair of Super M Diesels, all have moved on to new homes. Presently a Super M T/A that came from the original owners, a strong 450, and 330, 340 and 350 Diesel Utilities, always have a few skiploaders around as profit projects. Just drug home a Deere 70, one of the larger "poppers" that is sitting with the cylinders full of brake fluid, hoping to get it un-stuck. Most of these old buggars, and the 8N in particular, were designed to be very simple and easy to work on, so the average farmer could maintain them, unless they really shit the bed, which was usually from abuse or lack of maintenance. My point is these old buggars are brutally simple, carbs and distributors are crude but work fine with minimal maintenance, and if you tinker with them keeping in mind that they are 40's and 50's technology, can be a lot of fun- so I try not to over-think them. It's amazing the ways the engineers made things work back then, and when you park that Deere 70 next to a Farmall M or the Fords, they couldn't be more different in design, but did the same work. The Funk stuff is fun, as they re-used as many components as possible from the original tractor and still kept it simple
Post by: chris401 on September 08, 2020, 01:45:24 PM
Now that we all know the next guy isn't green we can talk tractors in the Non-FE discussion section.
The man I bought my parts donor distributor from runs a 226 in his driver and a 254 at the Salt Flats. He wasn't familiar with the industrial camshaft grind either.
I am not apt to cut up or change an antique. I may swap a part or two, box it up and shelve it. I would like to find a 48 era appearing proofmeter from a different make for mine. Since the backhoe is a 1950 I still may hang a Ford proofmeter off the side of a generator looking tachometer drive alternator I found online.
Either of you have one of these on the antiques you deal with?
 https://www.walmart.com/ip/NEW-Alternator-Fits-Lucas-Case-Ford-Generator-W-Tach-Drive-Many-Others-2-YEAR-WARRANTY/615996290?wmlspartner=wmtlabs&adid=22222222223279963132&wmlspartner=wmtlabs&wl0=e&wl1=o&wl2=m&wl3=74973054451134&wl4=pla-4578572604979016&wl5=&wl6=&wl7=&%20wl10=Walmart&wl12=615996290_10000012260&wl14=tachometer%20drive%20alternator&veh=sem
Post by: frnkeore on September 08, 2020, 04:07:30 PM
I also have 2 Ferguson TO 35's that use that generator.
As long as you use the Fergie ratio to the generator and a Fergie tach, you should be fine.
Post by: chris401 on September 09, 2020, 09:06:31 AM
Thank's, pm sent.
