Author Topic: Distributor ID Help  (Read 3351 times)
FE4ME
Distributor ID Help
« on: April 21, 2021, 11:09:20 PM »
I have a dual point distributor that im trying to identify,
I dont know if it is for FE or 260-289 ?
Number reads C3AF-12127-AB with a date code of January 1963
anyone out there know what it is?
Re: Distributor ID Help
« Reply #1 on: April 21, 2021, 11:32:28 PM »
Per the Ford Parts book C3AF-12127-AB is a single point distributor from a 1963 full size Ford with 289 2 bbl with manual transmission and overdrive. That would make it seem the dual point is a conversion.
428kidd
« Reply #2 on: April 22, 2021, 08:45:54 AM »
Defiantly some type of conversion.  Factory ones have no place for a vac advance unit. Aslso not the little short points and Frankenstein screws going out the side of the case, not factory piece . Neat conversion all the same .
FE4ME
« Reply #3 on: April 22, 2021, 09:29:29 PM »
ok thanks,
I knew something was off
427John
« Reply #4 on: April 23, 2021, 04:27:30 PM »
Due to each set of points being strapped to separate terminal posts instead of to the same terminal post it could be for a dual coil system or it may be for 2 separate ignition systems like is common in Nascar type race cars.
