Author Topic: Piston to head clearance.  (Read 4622 times)
Mbowling
« on: April 20, 2021, 07:49:02 PM »
What is the minimum I can get away with on my 487.  Steel rod, street car. Will seldom go past 6K rpm.
69 GT500 SCJ
69 merc spoiler II 428SCJ
65 Custom R code
34 ford pu. 286” flat tie
64 brand X corvette
66 mustang coupe 289
79 fiesta turbo
GerryP
Re: Piston to head clearance.
« Reply #1 on: April 20, 2021, 07:55:45 PM »
Generally, you don't want to go much less than .040" and for sure not tighter than .035".  The quench zone is so tight that you actually have to build to it.  Less than .035" and you're probably going to see witness marks.  Though there are a lot of examples of just having witness marks at .030" but that's really too tight.  And over .070" and you start losing the quench effect.  You have to carefully measure every cylinder.
« Reply #2 on: April 21, 2021, 03:20:07 AM »
Tons of variables:  piston weight, rpm, piston rock, piston/cylinder clearance, dome/flat top, etc.
.040” is gonna be plenty safe unless it's a heavy domed piston.  I wouldn’t run tighter unless you want to experiment or have experience with that combination.
My 352 runs really well at .035”, but it’s a stable 1.920” compression height with no rock, with a flat top, .0035" of piston/wall clearance, and I do a ton of measuring.
« Last Edit: April 21, 2021, 04:44:05 AM by blykins »
« Reply #3 on: April 21, 2021, 05:57:31 AM »
I have run a pretty well refined 505 (4.350 bore, 4.250 stroke, 700+ HP, 6500 RPM) at .036 and upon teardown it had the machining marks from the head clearly visible in the carbon on top of each piston.  No metal movement that I could see, but it was definitely "right there".
Mbowling
« Reply #4 on: April 21, 2021, 07:26:06 AM »
Thanks. It was after a 15 hr workday when I was looking at it last night. So I need to recheck my measurements and check all cylinders top & bottom of the bore. I do have some piston rock so I’m thinking to use the measurements that put the piston closest to the head.
I’m fairly certain tho that I’ll need to increase my clearance, Are a custom thickness head gasket from cometic a good fix?
69 GT500 SCJ
65 Custom R code
64 brand X corvette
79 fiesta turbo
gt350hr
« Reply #5 on: April 21, 2021, 10:08:11 AM »
    .035 minimum is my limit. As Brent said piston weight and RPM are critical especially if a light weight ( read flexible) pin is being used.
