Author Topic: engine swap  (Read 5145 times)
dmazz
engine swap
« on: April 18, 2021, 07:21:41 AM »
We are in the process of putting a 390 in a 77 F150 custom 4x4 with stock truck 4 speed. We pulled a 302 out of it but the truck had a 351M from the factory. I have motor mount perches out a 76 4x4 390 truck and they only line up with 2 forward bolts on the inside of the frame (upper coil spring mount) and only the forward bolt hole on the top of the frame. We need some direction and this forum is the best place to find it. Surely someone here has done this. We would really appreciate your input. Thank you Denis
« Last Edit: April 18, 2021, 08:08:28 AM by dmazz »
66 Fairlane GT 427 4 speed Black
67 Mustang Coupe K Code Vintage Burgandy
93 Lightning Black
TimeWarpF100
Re: engine swap
« Reply #1 on: April 18, 2021, 12:54:06 PM »
The 4x2 stands and mounts are a dime a dozen but the 4x4 stands a bit tougher to find. Where are you located? I have a pair but do not ship stuff but can get you a pic what they should look like.
dmazz
Re: engine swap
« Reply #2 on: April 19, 2021, 06:49:45 AM »
Thanks, pictures would great, I'm Derry PA
93 Lightning Black
