Author Topic: Work in progress - My other than FE project.. A460 head 565" BBF ...  (Read 11252 times)
Wow
JC-427Stroker
Wow
Not bad for a set of 30 year old heads ......
JC-427Stroker
July 4th weekend ...  We did our share for MMGW burning lots of 100 octane.
Made a bunch of runs like this from 5 miles to 14 miles ..   4,500 - 4,600 rpm   58-60 mph, water temp 140*, Oil temp 205-210*
the impeller was turned back ( cut) to allow the engine to spin 6,600 ( absorbing approx 875 hp observed) it should run approx 105-108 at that rpm.  It wasn't getting fed enough water and was spinning 6,800 - 6,900 and running 101-102.  It needs a few hardware adjustments and should be close to the 106 goal at 6,600.
https://vimeo.com/571890226
« Last Edit: July 14, 2021, 12:56:37 PM by JC-427Stroker »
JC-427Stroker
Constipated?  Go barefooting behind one of those.  Problem solved  :o :o
WerbyFord
Superb!
The Green Kids today talk of Clean Power.
The CLEANEST SOUND comes from open headers. Hard to argue that.
Is that 4v intake the Ford Motorsport Single or other?
I guessed the headers at 2-1/8 primary, 3-1/2 collectors. Obviously open.
JC-427Stroker
The single intake is the TFS single “Hi Rise” it’s the second generation single 4.
JC-427Stroker
Re: Work in progress - My other than FE project.. A460 head 565" BBF ...
« Reply #22 on: October 03, 2022, 11:37:16 PM »
Did some modifications to another TFS tunnel ram.   Had spacers built for the plenum. Changed runner length, entry area, entry angle, reduced taper.  It took quite a bit of epoxy work to get the spacers matched up to the new runner design.
Did a baseline with the old manifold. The engine was off 2% from last year. At 1,000 hp  2% equals 20 hp. We contribute the power loss to not having a fresh hone and valve job. It's not pulling the vac it once did, so I think it's going out in the rings.  Need to do a leak-down this coming weekend. The engine has several 100 miles on it from river running.
The goal was to build a better tunnel ram better suited for a 565" engine operating in the 5,000 -7,500 rpm range. Target was max HP at 7,200.  Still has the small cam in it 275/277 @ .050,  lobe lift .455-.420 with 1.8 rocker.  113 lc
Manifold swap  on the dyno:
Modified intake in red.  Baseline old manifold in blue:
I'm hoping with a bit of service this winter it picks some power backup and we can see 1,000 hp at 7,200 and 790 lbs ft at 5,600 -5,700.  It should be achievable.
« Last Edit: October 04, 2022, 12:41:34 PM by JC-427Stroker »
