Author Topic: Tremec TKX in Fairlane - Scatter Shield question  (Read 9792 times)
fairlaniac
« on: March 25, 2021, 01:35:30 PM »
So I'm thinking of putting the TKX in my '66 Fairlane. Since I put my 427/484 stroker in my Fairlane I don't have the desire to wind it out with my toploader on the highway. I don't drive much on the highway. I'd say from home to Carlisle Ford Nats round trip 140 miles. However I'm usually taching just shy of 3500 RPM with my 3.89 gears (when I had the 390 in the car). I thought it might be time for a 5 speed. I'd like to keep the unnecessary RPM's off the 427. So I'm taking inventory of what I may have on hand. Does the Lakewood scatter shield work with a TKO?
Thanks!
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
Re: Tremec TKX in Fairlane - Scatter Shield question
« Reply #1 on: March 25, 2021, 01:39:50 PM »
I run a shortened input TKO-600 in my Mustang with a Lakewood, bolt in.  The input was the same length as the old RUG-AE2
I don't know what the TKX is using, but would expect it may be a bit long without a cut or spacer
wowens
« Reply #2 on: March 25, 2021, 03:35:43 PM »
I like the Quick Time bellhousing , lighter and leaves more clearance in the tunnel.
Any aftermarket bell will cause geometry issues with your stock linkage so I would use the factory bell unless your racing.
Buy the trans with a short shaft and other than shifter location it should bolt right in just like the toploader.
Woody
« Reply #3 on: March 25, 2021, 03:57:06 PM »
I been thinking of getting the TKX too for my Fairlane , short input shaft I think is what Brent said to use with FE
« Reply #4 on: March 25, 2021, 04:52:01 PM »
You can use the short or standard either one with an FE.  Just needs the right bell and a little shifter handle finagling.
JamesonRacing
« Reply #5 on: March 26, 2021, 06:19:52 AM »
Changing from a top loader to a modern 5-speed is a game changer.  That overdrive gear makes all the difference in the world for the 90% of the time you're using your street car.
A shortened input shaft is the way to go. Driveshaft length and bellhousing/scattershield remain the same, shifter location is better on a TKO, but a TKX may be a different solution.
Gregwill16
« Reply #6 on: March 26, 2021, 07:19:36 AM »
Jameson are you saying the TKX shifter location is not ideal, as in different than the TKO?  I have a TKO I plan to use in my 69 Mustang, if it will fit without modification. But I'm guessing that will not be reality, so was thinking of getting a TKX since they are smaller. But if they cause other issues, may reconsider.
« Last Edit: March 26, 2021, 09:10:02 AM by Gregwill16 »
JamesonRacing
« Reply #7 on: March 26, 2021, 03:48:49 PM »
I have no experience with the TKX transmission, but it looks to have a different shifter that the TKO.  I know what worked for my with the TKO, just unknown for the TKX.  I'm kicking around replacing my current TKO in my 66GT with a TKX since it seems to have synchros that will work up to 7500 rpm.  The TKO is limited to 6500 or less from my experience.
fairlaniac
« Reply #8 on: March 27, 2021, 10:17:39 AM »
David,
Were you able to use the factory crossmember with your TKO? Which input shaft did you use?
Thanks,
Doug Bender
1978 F150 2WD 390
hbstang
« Reply #9 on: March 27, 2021, 01:34:05 PM »
i am saving up for one of these.already have the core and front plate.up to 1,000 hp rating!with all the fixes they do are suppose to be stronger and better shifting than the tko.i guess the tkx is just an updated tko.
http://cart.hanlonmotorsports.com/tr-3650-5
JamesonRacing
« Reply #10 on: March 27, 2021, 02:37:05 PM »
David,
Thanks,
Yes, used the factory crossmember.  The input shaft is a top loader-length 26-spline version that I purchased from Brent.
« Reply #11 on: March 27, 2021, 04:46:22 PM »
Does this new TKX have provisions for a factory mechanical speedometer cable setup? Other than changing to a 26 spline clutch disc, was everything else a bolt in for an FE application?
winr1
« Reply #12 on: March 27, 2021, 06:35:45 PM »
After buying a TKX, do yall sell your TKO's ??
What would a used TKO go for if I may ask ??
After seein what top loaders are going for, I might look for a TKO for my 65 F100
Ricky.
wowens
« Reply #13 on: March 27, 2021, 06:52:39 PM »
Mechanical on drivers side, electric on passenger side.
Woody
fairlaniac
« Reply #14 on: March 29, 2021, 08:22:37 AM »
David,
Were you able to use the factory crossmember with your TKO? Which pilot shaft did you use?
Thanks,
David,
Is the pilot bushing the same or will that change?
Thanks,
« Last Edit: March 29, 2021, 01:07:31 PM by fairlaniac »
Doug Bender
1978 F150 2WD 390
