Author Topic: Slip Fit headers / Side Pipe install  (Read 4462 times)
PaulProe
« on: March 22, 2021, 07:34:01 PM »
I am getting ready to install/assemble my individual tube slip-fit headers into a replica cobra. Any tips on the slip-joint as to sealing compounds and best way to do it without creating a f%$*#*  mess.
I've had them together before, it's a tight fit and really a task to get everything in place and lined up. I am thinking Permatex Red Hi-Temp compound inside the female tube and then slip the individual tubes in. Other ideas or suggestions
Paul
1967 XR7 GT
Re: Slip Fit headers / Side Pipe install
« Reply #1 on: March 22, 2021, 08:33:38 PM »
I wouldn't use any sealant.
I use a high temp anti-sieze compound,
for ease of assembly and disassembly.
Metal expansion when they get hot is what seals them.
Richard
475fetoploader
« Reply #2 on: March 22, 2021, 10:11:51 PM »
Ditto
1967  519 c.i.  TKX 5 speed
winr1
« Reply #3 on: March 23, 2021, 01:57:23 AM »
As said above ...  high temp anti-sieze compound
I would use copper over nickel perhaps ...
Ricky.
HTM101
« Reply #4 on: March 23, 2021, 08:28:06 AM »
I have individual primary pipes on my pretend Cobra.  Several years ago I tried the red RTV because of O2 sensors recently installed.  The RTV was a fail for sealing.
I've had the pipes on and off many times during 27 years of ownership.  The easiest side pipe installation for me has been:
a. Bolt on the the individual primary pipes, leaving them somewhat loose.
b. Use wood blocks to hold the side pipe in its almost-installed position.
c. Spray the ends of all pipes with a bit of WD40 before insertion.
After steps a., b. and c. I can get a side pipe and the 4 primary pipes joined in 1-2 minutes.  Occasionally a bit more time.
« Last Edit: March 23, 2021, 08:31:48 AM by HTM101 »
« Reply #5 on: March 23, 2021, 01:04:44 PM »
This.  Even works on the 1993 F-350 with the right side exhaust tick.  Get it warm and it shuts up nice.
427John
« Reply #6 on: March 24, 2021, 01:13:54 AM »
If its a good snug fit sealer shouldn't be necessary,the anti-seize is a great idea in case you ever have to take them apart again,but they probably still won't be easy.
