Author Topic: 61-64 full sized headers  (Read 5972 times)
gregaba
« on: March 12, 2021, 03:35:58 PM »
Don't know if this is common knowledge or not but I was on Jegs site today and found Hooker Super Comp headers for the 61 to 64 full sized Fords for $775.00.
1.875 x36 tubes
Part number 520-6205
Greg
allrightmike
Re: 61-64 full sized headers
« Reply #1 on: March 12, 2021, 04:42:38 PM »
Can anyone think of a reason these headers wouldn't fit a'60?
'60 Starliner 427 4speed.
« Reply #2 on: March 12, 2021, 10:00:29 PM »
The '60 352 HP in a Thunderbird had cast manifolds like was used on the 390 HP/406 if my memory still serves me correctly.  If those manifolds fit the '60-'64, then the headers should work.  Should be the operative word.  Joe-JDC
Val406
« Reply #3 on: March 13, 2021, 08:31:48 AM »
The Hooker pipes require that you cut the inner fender. Crites groups the body-style from 60-64 so the Hookers MAY fit.
https://critesperformanceparts.com/page6
shady
« Reply #4 on: March 13, 2021, 03:49:18 PM »
I'm thinking the 60 was a one year only frame. maybe wider after the A frames. And yes one header tube does go thru the inner fender and around the outside of the frame back to the collector.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
Lenz
« Reply #5 on: March 17, 2021, 07:33:16 AM »
Yep, 2 tubes do the same on the passenger side.  Inner fender had to be cut but it sure is nice for starter access (says the guy who made a hobby out of pulling the starter 'till he got everything right).  Unbolt 3 & 4 and they slide out of their joints with no hassle.  Doesn't answer the question about fit in a '60, these pics are in a '64, might give you a visual cue?
Len Zielinski
'64 Galaxie 500 445 Toploader
'69 F100 300 stick
