Author Topic: 2.09 intake and 1.56 exhaust valve  (Read 2760 times)
winr1
« on: February 25, 2021, 08:36:31 PM »
What would the outcome be ??
No combo in mind just curious as to others thoughts or experiences
Ricky.
« Last Edit: February 25, 2021, 11:27:50 PM by winr1 »
winr1
Re: 2.09 intake and 1.56 exhaust valve
« Reply #1 on: February 26, 2021, 04:06:49 PM »
Also ...
Any small table top lathes an FE piston would fit ??
I suppose max chuck size a bit over 4 " ??
Ricky.
« Reply #2 on: February 27, 2021, 04:03:16 PM »
Ricky.
I think that is hard to answer without some more detail, Ricky.  I understand you are talking hypothetical, but what situation are you talking about?.   So that would be a CJ size intake valve with a stock lo-po exhaust valve?
I think it would be better than using the stock 2.03" intake valve.   I think if someone had those valves laying around and was doing a stockish rebuild, they would work good.   I think a 2.09/1.66" combo would be better in most instances, but if you had the 2.09/1.56" valves I would use them if all-out power was not the primary goal.
paul
