Author Topic: Ported TFS FE Heads......  (Read 4926 times)
« on: February 05, 2021, 06:07:42 PM »
Trick Flow is in a national shortage for FE heads right now, but when they come back in stock I will be offering them ported.
In stock form, they will flow about 330 cfm @ .600" and start to back up after that, with a 220 cfm exhaust port.
In ported form, they flow 348 @ .600" and go up to 358 cfm @ .750".  Exhaust ports flow 225-228.
As measured, intake port volume has went up 5cc.  Instead of a 175cc port, they are now right at 180cc.
I will have a set on a 496 here soon.  Look forward to seeing the results.
(The vane is still there........)
« Last Edit: April 02, 2021, 01:07:00 PM by blykins »
667Litre
Re: Ported TFS FE Heads
« Reply #1 on: February 05, 2021, 06:11:29 PM »
Brent, do you have approximate pricing on ported vs unported, fully assembled?  Thank you.
« Reply #2 on: February 05, 2021, 06:22:04 PM »
Sure, I'll put pricing in the venders' section.
chilly460
« Reply #3 on: February 05, 2021, 08:35:05 PM »
Awesome, be interesting to see if the 235* hydro roller strokers like a little more flow.
351crules
« Reply #4 on: February 05, 2021, 10:51:42 PM »
are there plans for an all out port job with these heads? also is the porting only available to new head orders or can people send their heads in..
« Reply #5 on: February 06, 2021, 06:06:32 AM »
If I get an application where we can do a "max effort" port job on one, we may do that, but even in box stock form, they will support 700 hp easily.
I can have existing heads ported.
« Reply #6 on: February 06, 2021, 11:54:31 AM »
how much hp can the BBMs and cj heads support in stock form?
« Reply #7 on: February 06, 2021, 12:11:00 PM »
A rough rule of thumb is 2 hp per cfm.  That will depend on how radical the rest of the engine is, but it's a good rough estimate.  A CJ head will flow about 250 cfm, unported with good valves.  A BBM head will go somewhere around 280-290 cfm, also unported.
