Author Topic: Edelbrock 60059 head combustion chamber  (Read 3497 times)
winr1
« on: January 31, 2021, 10:14:26 AM »
https://www.edelbrock.com/rpm-ford-fe-390-428-cylinder-head-60059.html
Do any know if the 60059 combustion chambers look like the ones in the above link ??
Summit shows a different looking chamber
https://www.summitracing.com/parts/edl-60059?cm_mmc=ppc-google-_-search-_-brands-_-keyword&gclid=EAIaIQobChMImpDDz7nG7gIVqvLACh2bxgcfEAMYAiAAEgJwXfD_BwE
Also, can a truck header me modified to fit the heads ??
Ricky.
« Last Edit: January 31, 2021, 10:18:43 AM by winr1 »
gdaddy01
Re: Edelbrock 60059 head combustion chamber
« Reply #1 on: January 31, 2021, 12:05:36 PM »
the  summit ad says only one left , don't know if that matters to you , with the news of the company relocating or closing .
67xr7cat
« Reply #2 on: January 31, 2021, 04:36:42 PM »
I don't know the Edelbrock part numbers, but they have two versions of that head, the CJ and the 427.  The picture is of the 427 head's chamber. It may just be a wrong picture as the description says chamber is 72cc which is the CJ size. The 427 is 76cc. May want to ask Summit if it is the correct listing.
Btw keep in mind that is for one head and says only one in stock.  Unless you just need one you would need to find another and with edelbrock shutting down its old headquarters and reorganizing could be a shortage of castings for a little while.
winr1
« Reply #3 on: January 31, 2021, 09:51:30 PM »
Thanks yall
I would like a pulled in chamber such as the one in the first link with 2.09/1.65 valves
The Edelbrock link that is ...
Spacing to fit a 390 bore or 4.09
Ricky.
« Last Edit: January 31, 2021, 09:55:34 PM by winr1 »
