Author Topic: Which spark plug should I use?  (Read 3344 times)
james
« on: January 26, 2021, 05:17:01 PM »
Have a 427 FE with autolite plugs ap3924. Which one should I get? Autolite platnum.  Autolite copper core.  Autolite copper core resistor or autolite double platnum? Or is there another brand you would suggest? Thank You!
Re: Which spark plug should I use?
« Reply #1 on: January 27, 2021, 11:38:50 AM »
I run plain copper core in my older race engines.  The dragster heads use a NGK plug that has some other weird-tanium material but is the correct thread and heat range.  The 351Cs and such have all run Autolite copper core plugs for years.
james
« Reply #2 on: January 27, 2021, 06:25:30 PM »
Thank You for responding, I really appreciate it.
