Author Topic: Header build...All done!!!!!!  (Read 13269 times)
AlanCasida
Re: Header build
« Reply #15 on: January 29, 2021, 09:21:50 AM »
Did you get enough pieces to do both sides at once ?
Will each piece spin in the joining piece or are they pinned ?
Total cost of kit ?
I got the kit that is big enough for one side...almost. I could have used more straight pieces but I can get around that. Yes the pieces interlock and will spin and there is some tension on them that allow them to stay in place although when I get them the way I want them I put a piece of masking tape the length of the part to keep them in place. Each segment is about 1 1/2" long and the angled pieces are pie cut. The basic kit comes with angled pieces for 3 different CLR. Since the header kit I bought only had J-bends for 3" CLR I called them and they made up a kit for that. My kit was about $450. Like I said, kind of pricy but it is so much easier to mock up and I can experiment with different styles without cutting a single piece of tubing.
KMcCullah
Re: Header build
« Reply #16 on: January 29, 2021, 04:07:54 PM »
Looks good, Alan!  8) Man I wanted one of those modeling kits when I first discovered them. Just couldn't bring myself to cough up the coin. Ended up putting the money into mandrel bends and winged it. For a tight engine compartment, the modeling kit would be an awesome tool.
This guy I found on epay had pretty good mandrel bends if your looking.
https://www.ebay.com/str/GetBentMandrelBending?_trksid=p2047675.l2563
Kevin McCullah
GJCAT427
Re: Header build
« Reply #17 on: January 30, 2021, 09:48:22 AM »
 I`ve been looking at the Ice kit for a couple of yrs. I have`nt made the jump yet, I got to justify the cost against the project.
AlanCasida
Re: Header build...One down and one to go
« Reply #18 on: February 08, 2021, 06:31:42 PM »
I got the driver's side finished. The scary thing is they actually fit! AND I can get them out of the car with relative ease. I made #7 tube with a slip fit to aid in removal. I think the passenger side will go easier since I don't have to contend with the steering shaft.
« Last Edit: February 08, 2021, 07:12:35 PM by AlanCasida »
winr1
« Reply #19 on: February 08, 2021, 10:39:01 PM »
Looks great !
Ricky.
gdaddy01
« Reply #20 on: February 09, 2021, 02:53:50 PM »
nice job , I would say they look outstanding , having made headers before , yours look better than mine .
« Reply #21 on: February 09, 2021, 05:11:32 PM »
Wow! those looks great
Leny Mason
« Reply #22 on: February 09, 2021, 05:33:43 PM »
Nice They look great !!!!!
66FAIRLANE
  • Andy
« Reply #23 on: February 09, 2021, 07:03:26 PM »
Looking great!
KMcCullah
« Reply #24 on: February 10, 2021, 08:26:02 AM »
Looking good, Alan.  8)  A few removable tubes might be necessary on the starter side.
Kevin McCullah
« Reply #25 on: February 10, 2021, 08:12:10 PM »
Nice job!
AlanCasida
Re: Header build...All done!!!
« Reply #26 on: February 25, 2021, 08:33:25 PM »
I finished up the passenger side today. Clearing the starter and still being able to remove the header with the engine in the car proved to be a little more challenging that I thought but I got it. Tubes 3&4 have a slip fit coupling so they are removable. While building these was kind of fun I don't think I want to do another set for awhile...a long while!
« Last Edit: February 25, 2021, 08:57:29 PM by AlanCasida »
Bolted to Floor
Re: Header build...All done!!!!!!
« Reply #27 on: February 26, 2021, 10:42:28 AM »
Looks like a work or art!!! Great job.
« Reply #28 on: February 26, 2021, 12:58:22 PM »
They look great Alan.  Did you use a TiG setup?  One of my bucket list projects is to get really decent at TiG welding.
AlanCasida
« Reply #29 on: February 26, 2021, 02:42:45 PM »
Yes I TiG welded most of it. And like most of the stuff I do , it don't look too bad if you don't look too close. :) I cannot and will not ever be able to lay down the "stack of dimes" I lack the skill and control for that. I did MiG weld the collector to the tubes too.
