Author Topic: Spark plug question  (Read 4070 times)
SReist
Spark plug question
« on: January 01, 2021, 06:13:16 PM »
I need to find a replacement plug that closely matches the BF32 Autolite. I have narrowed it down to three choices. The NGK
AP6FS, NGK AP7FS or the Autolite AR33. The engine is a 428CJ block, 4.125 Scat crank and flat top Diamond pistons. Induction
is a BT 428CJ intake, Quick Fuel 780VS and Lunati .509 @260 solid cam and stock CJ heads. Thanks in advance, Steve
Re: Spark plug question
« Reply #1 on: January 01, 2021, 06:29:07 PM »
For higher compression stuff, I'll use an Autolite 124 or an AR 32/33.
« Reply #2 on: January 02, 2021, 06:17:33 AM »
I use NGK AP6FS of the simple reason it is what i can buy here
with least problem they works perfect
KMcCullah
« Reply #3 on: January 02, 2021, 10:22:05 PM »
I've won a lot of races and putted around town with Autolite 124's.
Kevin McCullah
SReist
« Reply #4 on: January 03, 2021, 01:36:33 PM »
Thanks to all. At least I'm on the right track. Steve
