Author Topic: What is everyone using for Sonic Tester conductor fluid  (Read 4846 times)
« on: December 22, 2020, 08:25:06 AM »
Feels like a "blinker fluid" question LOL
I have been using white grease, actually Comp white assembly lube in the little plastic tub, and it works fine, but I was running low and cracked open the little bottle of clear fluid that came with my tester.  Clear, squeeze bottle, a little thinner than the white grease I was using, and it was so much easier to control and then clean up after.
Anyone got a good brand / supplier that they like?  I bought some a while ago, but it was runny which pushed me to the grease. I have two to do this weekend, and may try a different white grease from a tube, but wondering what others are buying
Thanks!
Re: What is everyone using for Sonic Tester conductor fluid
« Reply #1 on: December 22, 2020, 09:04:19 AM »
Glycerine works well.
« Reply #2 on: December 22, 2020, 09:37:11 AM »
We are talking for the sonic check right?  LOL  Do you just buy from a drug store?
« Reply #3 on: December 22, 2020, 10:24:52 AM »
Amazon.  Has pretty close consistency to the stuff that comes with the sonic testers.
« Reply #4 on: December 22, 2020, 12:18:58 PM »
"bedroom butter"  AKA KY
« Reply #5 on: December 22, 2020, 12:29:10 PM »
You dirty dog you. :o
« Reply #6 on: December 22, 2020, 12:30:44 PM »
LOL!  Vaseline works pretty well.  I mean, for the sonic tester... :o
« Reply #7 on: December 23, 2020, 01:59:35 AM »
I tried several thinner greases but, the moly grease I'm using now, is thicker and tests well on the sample that it comes with the unit and a section of cast iron that I use. It also have given me a quickest reading.
I haven't used it on my block yet but, in the ports on SBF heads, where it's hard to get a good contact. The white lithium sounds good and I'll test it next.
« Reply #8 on: December 23, 2020, 07:47:18 AM »
Thanks guys, I bought some purpose made stuff before and it was too thin, white grease works but messy for me (although I used Comp Assembly lube, might be different than pure white lithium)
I am going to try to find a brand and part number so I can repeat the purchase later and will post back.  Lots of options here to try until then though
« Reply #9 on: December 23, 2020, 09:36:46 AM »
C'mon, Ross. Just suck it up, go to your local pharmacy and ask the counter lady for their biggest tub of KY  ;D ;D
