Author Topic: engine mounts on 400  (Read 5295 times)
« on: February 27, 2013, 04:29:06 PM »
Do any one know if the 400m have the same
engine mounts as the smallblock/Cleveland
I have oportunity to trade a 400 i have for a
410 FE. But to reach the 400 i have to shovel
a lot of snow i front of the barn i have stored
it in. And move a lot of good to have parts
just to see what kind of mounts it have.
Or better if any one can tell what it takes
to swap the 400 in place of the 410
 in a 64 Mercury
427Fastback
Re: engine mounts on 400
« Reply #1 on: March 01, 2013, 01:22:55 AM »
I havent touched a 400 in 20 years but my memory says no.I believe the block is drilled and tapped like a FE but different pattern..90 % of all the 400's use the 385 series bellhousing,There are a few that are dual drilled with the windsor pattern as well...
In stock configuration I would not trade a brand new 400 for a worn out 410..
Alot of work for disapointing results
JMHO...Cory
1936 Diamond T 212BD
1990 Grizzly pick-up
« Reply #2 on: March 01, 2013, 05:08:04 AM »
I have the 400 and get the 410  ;D
i know the bellhousing patern is
same as 385 what i want to know
is the actual motor mounts on the
block. are they like the windsor
cleveland with 2 bolts horisontal
from the underside
or are they like the 385 or are they
one of akind
20 years since i scraped the Ltd
where the 400 came from so i dont
remember
I can dig in to the engine but about
a whole days work
GJCAT427
« Reply #3 on: March 01, 2013, 06:57:30 AM »
351m/400 were different than the cleveland/ windsor mts. not aure if there the same as 385s.
