Author Topic: Oil restrictions to the rockers  (Read 4323 times)
Sand hauler
« on: December 19, 2020, 11:29:21 PM »
Was wondering if there is any way to restrict the oil to the rockers with out having to pull the heads?
Bobby-   Carlsbad, NM
Keith Stevens
Re: Oil restrictions to the rockers
« Reply #1 on: December 20, 2020, 04:47:44 AM »
Yes. It doesn't require head removal. Just rocker shafts. Most use a #70 Holley jet in the rocker feed for factory heads.
Sand hauler
« Reply #2 on: December 20, 2020, 08:10:21 PM »
I thought so, but wanted to make sure,lol
Bobby-   Carlsbad, NM
« Reply #3 on: December 21, 2020, 12:53:27 PM »
Keep in mind, the jet trick is for iron, aluminum is smaller OD.  I generally tap alum, but I suppose you could do a press fit if you didn't want to drill
Keith Stevens
« Reply #4 on: December 21, 2020, 01:58:17 PM »
I had to tap my Eddelbrock heads for the restrictors. They come in POP's oil galley kit.  I think it was 10-24 and the orifice in his kit is .090.
The OP didn't mention Edelbrock or aluminum heads. I would presume they were iron in that case.
« Reply #5 on: December 21, 2020, 02:31:21 PM »
I think the OP has a couple of builds going/complete, just wanted to clarify.
Sand hauler
« Reply #6 on: December 23, 2020, 10:13:03 AM »
Yes these are Iron. Getting a little bit of oil in 7&8 cyl. Not much. Figure it is prob from too much oil on top .
Bobby-   Carlsbad, NM
