Author Topic: Cutting excess intake gasket off protruding into V/C Rail.  (Read 5827 times)
Keith Stevens
« on: December 08, 2020, 12:41:13 AM »
I used the 1247-S3 with the steel shim. A slight amount protrudes into the VC rail area. What are we cutting this off with?
Re: Cutting excess intake gasket off protruding into V/C Rail.
« Reply #1 on: December 08, 2020, 04:56:06 AM »
I trim gaskets on mock-up with a razor blade or with tin snips.
rockhouse66
« Reply #2 on: December 08, 2020, 08:03:31 AM »
Some will cringe, but I hit it with a chisel.  Makes a nice sharp close cut.
Jim
Keith Stevens
« Reply #3 on: December 08, 2020, 08:11:15 AM »
I am stuck with something like a chisel at this juncture. I used the Mr Gasket and they got soggy. It's why I went to the 1247 -S3 this time. Always a learning curve as there are constant changes to products.
DuckRyder
« Reply #4 on: December 08, 2020, 08:44:21 AM »
I did mine with a gasket scraper (razor blade)
Robert
Keith Stevens
« Reply #5 on: December 08, 2020, 10:24:05 AM »
A razor won't cut gaskets that have a steel clad.  Mr Gasket and others that are just fibrous materials are easy to cut with a razor.
« Reply #6 on: December 08, 2020, 10:41:17 AM »
When all else fails, peel off the soft material, and bend the steel tab towards the lowest side of the gasket, and dab a bit of sealer on the area.  The valve cover gasket should still seal the juncture.  Joe-JDC
Keith Stevens
« Reply #7 on: December 08, 2020, 10:47:33 AM »
Thanks. I didn't think they'd be that difficult to cut. Lesson learned.  I have a .50 rail mis-match too. Doesn't help with sealing, even with the thick composition Edelbrock VC gaskets.
Phil Brown
« Reply #8 on: December 08, 2020, 12:29:22 PM »
X2 on a chisel if you forget to trim it before, watch where the little piece goes  ;D
rockhouse66
« Reply #9 on: December 08, 2020, 08:08:53 PM »
Yes!  Good tip.
Jim
DuckRyder
« Reply #10 on: December 08, 2020, 08:39:32 PM »
I used S3’s. I also did not care for the MRG’s.
Now that you mention it I do have a scraper that takes a carpet knife blade, but I’m almost positive cut them with a gasket scraper, the metal isn’t that thick in them.
A chisel would certainly work too.
Robert
C8OZ
« Reply #11 on: December 08, 2020, 09:20:13 PM »
I think this horse is plenty beaten, but also fret cutters are great for trimming things flush.
AlanCasida
« Reply #12 on: December 08, 2020, 11:34:08 PM »
Well I have just beat them over with a hammer before. also cringe worthy. :)
