FE Technical Forum
Edelbrock heads. Before using the Time-sert helicoil removal?
Topic: Edelbrock heads. Before using the Time-sert helicoil removal? (Read 3119 times)
Keith Stevens
Full Member
December 07, 2020, 11:26:47 PM »
The coil is only partially pulled. Is it safe to drill them out or do I need to use another method to remove the coil before hand?
Re: Edelbrock heads. Before using the Time-sert helicoil removal?
Reply #1 on:
December 07, 2020, 11:48:23 PM »
I wouldn't drill out a heli-coil. They are best removed by twisting out with a needle nose. You can use a pick or center punch to get the end started, then grab the pliers.
Reply #2 on:
December 08, 2020, 04:56:42 AM »
X2, get the end loose and start unraveling it.
YouTube: Lykins Motorsports
FE Technical Forum
