Author Topic: Temp block preservation  (Read 3736 times)
« on: December 03, 2020, 08:59:23 AM »
Hi gents
Finally getting close to receiving my CJ block back from the machine shop.
I’ll be putting it together myself in my garage. It is not a controlled environment so the temp is way variable.
On my long storage blocks I slather on 30 wt with my hand and put a bag over them.
My question is, in a garage environment what would you use if you’re doing a slow build?
Is there a light spray that would fill the bill?
475fetoploader
Re: Temp block preservation
« Reply #1 on: December 03, 2020, 11:06:37 AM »
I’ve had great luck using SP-400, it’s an aerosol product from CRC.
1967  519 c.i.  TKX 5 speed
« Reply #2 on: December 03, 2020, 11:16:18 AM »
Thanks
These are the types of products I’m thinking about.
I’m wondering if they would leave a residue that may not be ideal for a build.
The more I think about it slathering on 30 wt by hand works.
I’ll just chalk that up to pre coffee mind wandering.
« Last Edit: December 03, 2020, 11:23:41 AM by turbohunter »
« Reply #3 on: December 03, 2020, 01:26:15 PM »
I use light wt hydraulic oil, in a heavy duty spray bottle.
« Reply #4 on: December 03, 2020, 02:13:51 PM »
Aah, good idea.
Thanks Frank.
RustyCrankshaft
« Reply #5 on: December 03, 2020, 06:53:14 PM »
LPS1 or 2, keep the moisture off, easy to clean up and doesn't make a mess applying it.
« Reply #6 on: December 03, 2020, 07:08:59 PM »
I like that stuff and to me, it has a excellent smell to it.
