Author Topic: 427-427 fe parts  (Read 5443 times)
64tbolt
427-427 fe parts
« on: February 22, 2013, 04:59:23 PM »
428  block tri web, C scratch, 9E2 date, 1800.00, 428 block tri web, C scratch, 9A2 date, 1800.00,  427 block C5ae-A, fresh .030 over, center oiler, 4J19 date,2500.00, 427 block, c4 center oiler, fresh machined, hard block to bottom of water pump holes, .050 over, aligned honed, sonic tested, great block for stock or super stock 2500.00,  high riser tunnel ram ron ross sheet metal  fabricated manifold using ford base casting,  1300.00,   new old stock still in the box ford single 4 barrel high riser  c4ae-9425-g  intake manifold  900.00,  contact mike at 517-927-4772....
rockhouse66
Re: 427-427 fe parts
« Reply #1 on: February 22, 2013, 06:02:14 PM »
For the benefit of others, based on the area code this seller is located near Lansing, MI.  I find this information helpful when considering the purchase of 500# of something.
Jim
