Author Topic: Dropping in the distributor.... DUH!!  (Read 4080 times)
Keith Stevens
« on: November 23, 2020, 11:37:49 AM »
I just went through installing the complete factory air in my mustang. Because I was pulling a little oil and the intake gaskets looked soggy I pulled the intake in the process.
I had marked the distributor and the intake and wound up wiping the mark off with brake cleaner.
I have always set the damper at 0 and The rotor pointing at #1. Is there a better method? did I miss something?
I know many of you do this day in-day out and with the lateral bracket in place it's a real bitch to get to the bolt that holds the clamp down.
Any secret methods to guarantee it's right the first time would be appreciated. Thank you!
« Last Edit: November 23, 2020, 07:54:44 PM by Keith Stevens »
Re: Dropping in the distributor.... DUH!!
« Reply #1 on: November 23, 2020, 11:49:54 AM »
Pull the passenger side valve cover, watch the exhaust valve open then close, then watch the intake valve open.   Keep turning and when the intake valve is closing, you will be getting closer to TDC on the balancer.  Stop when it's about 30° BTDC and then point your rotor at #1.  Guaranteed to light off immediately.
Keith Stevens
« Reply #2 on: November 23, 2020, 11:58:43 AM »
That makes perfect sense but.... It has AC and an Export brace. I would have to unbolt the shocks, beehives, bolts from the cowl, remove the Heater hoses and then of course the wires from the cap and then the cover? Any other cheats?
« Reply #3 on: November 23, 2020, 12:06:34 PM »
Stick your finger in the #1 plug hole, when it starts to come up on compression stroke it will try to blow your finger out.   Try to stop it before TDC though.
cleandan
« Reply #4 on: November 23, 2020, 06:07:50 PM »
Take a digital photo of the distributor, with the cap removed and rotor in place, before removing anything further.
This gives a great visual reminder about how things were prior to taking things apart.
Make sure your timing marks are good so you can trust them.
Remove the spark plug from #1 cylinder.
Rotate crank in correct direction until pressure comes up in #1 cylinder.
You can detect pressure with your finger, or any number of tools you can make from an old, gutted, sparkplug.
Once you have pressure being built, and you are certain you are on the compression stroke, not exhaust, then stick a small dowl into #1 cylinder through the spark plug hole.
This dowl does not have to be stout, just stiff enough to not deflect easily.
I use a 1/8" wood dowl because it fits easily, does not jamb, but provided enough ridgidity to get the job done. Besides, none of the wood particles left behind will cause harm to the engine.
With the dowl inserted, and the piston still coming up to TDC, slowly rotate the crank until you find TDC. Not the rotor location makes sense and matches closely to what you had prior to work.
You will likely go past TDC on the first attempt...No big deal, just go around again, but pull the dowl out before going further so you don't drop it in, or mash it somehow.
This time as you come around to TDC pay close attention to your timing marks.
Like Brent said, stop at 30* BTDC and set things up.
This should get you started and running. Once running get the light and set things just right.
427Fastback
« Reply #5 on: November 23, 2020, 10:54:17 PM »
I do it a little different...I pull the drivers valve cover and watch #6...I rotate the engine by hand and I watch the marks and watch the valves on #6..one coming up and one going down or on the rock and the marks getting close has #1 on compression if not roll it over one more time.I set the marks to zero andI drop the dist in where it should be and advance it a little..They always fire up with out a issue....Just like setting hyd lifters everybody has their preferred way....
1936 Diamond T 212BD
1990 Grizzly pick-up
Keith Stevens
« Reply #6 on: November 24, 2020, 07:03:17 AM »
Okay, Is the 30 BTDC with the distributor completely seated?
« Reply #7 on: November 24, 2020, 07:27:01 AM »
Yes
Keith Stevens
« Reply #8 on: November 24, 2020, 01:26:11 PM »
Brent- Thank you! I dropped the distributor in very close. I did the usual, pulled the #1 plug and turned to to 30 degrees instead of zero. The rotor was about 1/2" from the #1 mark on the distributor. I turned it to the #1 mark and and it seemed slightly advanced. I turned it back just a touch and it lit right up.
I appreciate the tip. I have done this many times, but the the lateral support for the york compressor really makes it difficult.
Thanks again for the help.
