Author Topic: Dove pie heads  (Read 5856 times)
fastback 427
Dove pie heads
« on: November 01, 2020, 12:56:48 PM »
Found some pretty cool stuff on Facebook.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
Dumpling
Re: Dove pie heads
« Reply #1 on: November 01, 2020, 02:17:18 PM »
What does "0" swirl mean/imply?
Re: Dove pie heads
« Reply #2 on: November 01, 2020, 05:47:34 PM »
Numbers like that tell me there is no instrumentation hooked up to measure swirl.  On a flowbench, a device called a "swirl torque meter" is often used in the space below the chamber.
You can see a diagram of a swirl torque meter here (Sorry - Couldn't link the image...):
https://www.researchgate.net/figure/Swirl-torquemeter-principle-of-operation-7_fig1_254758698
Ghoughton
Re: Dove pie heads
« Reply #3 on: November 01, 2020, 08:17:37 PM »
Scott did a nice job on those. Really impressive numbers
Dumpling
Re: Dove pie heads
« Reply #4 on: November 02, 2020, 12:24:25 PM »
Thanks. But isn't swirl important?
Re: Dove pie heads
« Reply #5 on: November 02, 2020, 12:41:07 PM »
Swirl tends to improve lower-end torque, due to better charge motion / improved fuel mixing.  At higher RPM it's far less important than overall flow.  This looks like an all-out race port that's optimized for top end HP.
FrozenMerc
Re: Dove pie heads
« Reply #6 on: November 02, 2020, 01:33:25 PM »
Swirl is much more important with diesels due to the shape of combustion chamber and the way the injectors introduce fuel into the cylinder.  Large amounts of swirl are necessary to promote homogeneous mixing of the fuel and air during the injection phase, which in turn aids in power production, a clean burn, and ease of starting.  The intake ports are designed to optimize swirl because of this and swirl in a diesel will be as much as 3 times faster than a similar sized gasoline engine.  Many a back yard engine builder has screwed up their diesel cylinder heads trying to port them using a gas engine mentality.
Gale Banks has put together a bunch of good information on swirl if your are interested in more reading.
https://official.bankspower.com/what-are-squish-and-swirl-and-why-are-they-important-in-a-diesel-engine/
« Last Edit: November 02, 2020, 01:36:53 PM by FrozenMerc »
Re: Dove pie heads
« Reply #7 on: November 02, 2020, 02:25:27 PM »
Nice post, FrozenMerc!  That clearly explains something I had only heard about.
- Bill
