FE Technical Forum
BBM cast iron Block torque specs
Topic: BBM cast iron Block torque specs (Read 3396 times)
Jb427
Sr. Member
October 25, 2020, 02:23:11 AM »
Is the BBM iron block main and cross bolt torque spec's the same as a std 427 cross bolted block? The BBM has 7/16 cross bolts being larger then std?.
Re: BBM cast iron Block torque specs
Reply #1 on:
October 25, 2020, 04:44:00 AM »
It’s different because the fasteners are different. I use 110 on the mains and 55 on the side bolts.
YouTube: Lykins Motorsports
Jb427
Sr. Member
Reply #2 on:
October 25, 2020, 05:46:24 AM »
I thought so Thanks
Reply #3 on:
October 25, 2020, 08:28:58 AM »
The sheet I have says
Mains: 35-70-110 (3 steps)
Sides: 30-65 (2 steps)
Reply #4 on:
October 25, 2020, 08:50:55 AM »
Whoops, yes, 65, fat fingered the 55, laying in bed using my phone.
I do use 3 steps on the side bolts too though out of habit.
FE Technical Forum
