Author Topic: compression ratio  (Read 4069 times)
galaxastang
compression ratio
« on: February 19, 2013, 07:52:17 PM »
67 390 stock rebuild .30 over, 9 to 1 ? Are there any calculators out there or would factory specs be close? Thanks
Re: compression ratio
« Reply #1 on: February 20, 2013, 11:03:37 AM »
There are lots of calculators for compression ratio, but they all require the exact
measurements of the engine to give you an accurate number.
You can guess on a few, but it is just a guess.
The piston is the biggest factor.
Most 67 390's where in the 10.5 to 1 range.
For the most info you would have to give all the specs you can for your engine.
Here's a whole pile of configulators.
http://www.wallaceracing.com/Calculators.htm
