Author Topic: turbo engine spark plug type  (Read 4598 times)
fe-starliner
« on: October 01, 2020, 09:36:09 AM »
My friend Bill, who is a Ford guy and has owned several FE powered cars in his 68 years, has almost completed his build of a 300 Ford six with turbocharging and fuel injection.  He's searching for info on a good spark plug to use.  I've told him of the good help and information always available on this site (he's not a member of any forums) and he asked me to post this.  Of course it's 18mm with the iron Ford head.  Any turbo guys have suggestions I can relay to him?
Thanks.
1960 Starliner, 406-6V, TKO-600, 4.11 9"
1961 Starliner, 427 4V, SS700 5 speed, 4.56 9"
1968 F-100 SWB, 352 4V, C6, 3.25 9"
2012 Mustang, 226" V6, 6 speed auto, 3.31 8.8"
BigBlueIron
Re: turbo engine spark plug type
« Reply #1 on: October 01, 2020, 10:04:52 AM »
The old Autolight 124 isn't a bad place to start.  Might need to tighten the gap just a little.
A couple non resister options, NGK A6FS or colder yet with more tip projection AP7FS. Probably want to stay with a resistor option with the fuel injection system.
Can't get the AR6FS anymore.
I'm sure there will be more replies from people more knowledgeable than me on spark plugs.
fe-starliner
« Reply #2 on: October 01, 2020, 10:36:12 AM »
thanks BigBlueIron, I'll relay the info to him.
wayne
« Reply #3 on: October 05, 2020, 12:26:26 PM »
Denso makes a copper u groove plug like accel i have had good luck with them rock auto has them at 1.34 each.
Hipopinto
« Reply #4 on: October 05, 2020, 06:36:16 PM »
My iron headed 2.3 turbo runs the NGK version with a heat range of 7 on E85
Depending on fuel that might be a decent starting place
Feel free to ask if I can help I will
Dave
« Reply #5 on: October 05, 2020, 07:50:24 PM »
E85 can tolerate a hotter plug as well as ignition timing close to naturally aspirated. If this gentleman is not running E85, I would start with a #9 heat range and go from there.
fe-starliner
« Reply #6 on: October 11, 2020, 08:59:27 AM »
Thanks everyone for your replies.  I have forwarded the info to him.
