Author Topic: Which timing set for quality and price ?  (Read 6881 times)
427HISS
« on: September 10, 2020, 11:31:47 AM »
A lot of company's have the double roller chain & billet steel gears.
So other than that, what makes one better than the other and why ?
Prices from $70 to $215?
Yellow Truck
Re: Which timing set for quality and price ?
« Reply #1 on: September 10, 2020, 11:57:07 AM »
Not an expert, but I will say that I wish I had Jay's timing cover and adjustable timing gear a few years back when I decided to advance my cam in the truck.
Getting the timing cover off and putting it back cleanly required dropping the oil pan, and pulling the timing gear off. At least the Ford Racing timing gear allowed for multiple mounting positions. It would have been nice to open an inspection plate, loosen a couple of screws, move it and tighten it back up.
I'd have paid a couple of hundred bucks to avoid all the extra work.
Paul.
chris401
« Reply #2 on: September 11, 2020, 02:26:33 PM »
I bought a MotorSports from Barry a few years ago. Ran mid 400 lbs for the first 9,000 miles. The last 31,000 have been stock pressures. Did a cam swap 6,000 miles back still very little chain deflection.
drdano
« Reply #3 on: September 11, 2020, 03:42:42 PM »
Fun I had with timing chains a while ago.  The FoMoCo boxed unit ended up being the winner out of the half dozen others I had problems with in one way or another: http://fepower.net/simplemachinesforum/index.php?topic=313.0
« Reply #4 on: September 11, 2020, 03:46:41 PM »
I have and like the Ford Racing one.  I don't know if it is better than others, but it has served me well for a long time.   No issues and the 9 position keyway is a must for me.  It allows you to get your intake centerline super close to where you want it.
pl
https://www.summitracing.com/parts/fms-m-6268-a390/make/ford
« Last Edit: September 11, 2020, 03:50:09 PM by plovett »
427HISS
« Reply #5 on: September 14, 2020, 08:21:28 PM »
How about Doug's at Precision oil pumps ?
Rollmaster Torrington Timing Assembly.
It's $180 and comes with a thrust plate and other included parts.
http://stores.precisionoilpumps.com/fe-ford-390-428-427-rollmaster-torrington-timing-assembly/
427HISS
« Reply #6 on: September 16, 2020, 12:35:11 PM »
Bump...
« Reply #7 on: September 16, 2020, 05:45:06 PM »
I have one of those sets with the thrust kit. Very nice parts. I had no problem with it. Fasteners are ARP.
427HISS
« Reply #8 on: September 16, 2020, 09:36:01 PM »
I don't think it's overkill for s street engine, but looks to be quality built and includes everything needed, some others don't.
Hard to believe that some well know company's are $80. So is the Precision oil's worth twice as much ?
« Reply #9 on: September 17, 2020, 08:24:56 AM »
I usually buy the 9 way Ford Racing sets, never had a problem.  The dragster runs a Rollmaster set, it's as tight as new after 3 years of racing, solid roller with open pressures near 600 lbs.
« Reply #10 on: September 17, 2020, 08:41:04 AM »
+1 on Doug’s roller set. Thought I’d try it and put many thousands of miles of traffic and desert abuse on it with no problems.
