Author Topic: 66 comet front end kit  (Read 4112 times)
« on: August 30, 2020, 05:03:36 PM »
my 66 has about a zillion miles on it and its getting pretty loose and it travels all over the lane,even when your trying to go straight.im looking for a complete rebuild kit with everything i need. anyone like to share some info on a good kit? thanks
cattleFEeder
Remember, RPM is your friend
Re: 66 comet front end kit
« Reply #2 on: August 30, 2020, 10:09:03 PM »
thanks,but i need stock or close to stock kit,bushings rod ends,ball joints,etc..
winr1
« Reply #3 on: August 30, 2020, 10:43:22 PM »
Looks like Rock Auto has everything but you have to add each part to cart
I have gotten good stuff from them, MOOG AC/DELCO, etc
Not FE but sourced older rotors and pads for my 2009 F150
I checked each rotor as to the thickness, weight and such and compared it to the originals
The rotors with odd names were thinner and weighed less
Found Made in the USA brake hoses for my 2001 Mustang
 The out of country ones were off from the originals and already had corrosion peeping through
Ricky.
« Reply #4 on: August 31, 2020, 08:36:58 AM »
Fryedaddy, +1 on Rock Auto. I got the Moog lower arms with balljoints from them for my '66 Fairlane and they've given excellent service.
« Reply #5 on: September 01, 2020, 08:24:59 AM »
Then when it's done, dial in 1.5 to 2.5 degrees of positive caster to get the wander out of it.
« Reply #6 on: September 01, 2020, 12:22:02 PM »
thanks for all the advice. what about those ebay kits that have everything in one kit.
Cobrajet2
« Reply #7 on: September 03, 2020, 03:30:34 PM »
Buy the MOOG stuff, if you can. As others have said.
Mike
