Author Topic: 428 block as claimed in ad Craigslist Houston area, not mine, don't know owner  (Read 3623 times)
hwoods
It would be nice if they could take the bag off it for a picture or two  :D
shady
I had a girl friend like that once.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
475fetoploader
I think we all have to do that once
1967  519 c.i.  TKX 5 speed
CX block is an industrial block, the rods are likely small bolt, seems about 1000 dollars high or more
- Block with full machine work assuming done nicely - worst case 2000, but that would be with real good machining and nice sonic check
- Crank - 350 but with the industrial cranks you need to check the crank closely, often they run a big pulley off the front and crack
- Rods - 75
- Pistons - not much, those are likely old Badger, original would have been marked "super" for no reason other than to make you feel good :)
Most are sleeved as well, Ford seemed to sleeve a lot of them, did a good job, but you usually find one in a block like that
Yes, there is 2 dots on the date indicating a replacement type block.  Price is reflective of the prices posted on Facebook.  Joe-JDC
