Author Topic: BP 428CJ Stroker - 465 Cubes  (Read 19770 times)
Re: BP 428CJ Stroker - 465 Cubes
« Reply #15 on: August 27, 2020, 03:20:42 PM »
I note that you show a pair of the old, cast iron Ford tri-Y's, in your Project thread. Are those the ones that you will use in the car, or the ones pictured on the dyno?
It might be very interesting to see what they(cast iron) would do to the engine on the dyno.
Those are up for reconsideration at this point. I was fine putting 500 horse through them but not sure if I'm ok putting 600. One of them got screwed up at the machine shop anyhow when I had the flanges flattened, so I had to buy another drivers side manifold that hasn't been coated yet.
Simple question, just curious where your dyno is located.
Joe, dyno is Jim Morgans. Blair is doing testing there until he has his own built.
« Reply #16 on: August 27, 2020, 09:40:42 PM »
Frank, if you go to page 3 of the dyno results, item 2 is Barry's 2017 FE with both headers and cast manifolds at the EMC.  Joe-JDC
« Last Edit: August 27, 2020, 10:18:31 PM by Joe-JDC »
« Reply #17 on: August 28, 2020, 01:45:04 AM »
Thank you, Joe.
427HISS
« Reply #18 on: May 29, 2021, 12:51:35 PM »
I want this engine specs, but with my stacked EFI and aluminum heads.
What are the cam specs ?
« Last Edit: May 29, 2021, 12:53:23 PM by 427HISS »
« Reply #19 on: June 01, 2021, 12:29:04 PM »
It's a bullet cam. Hydraulic roller cam with solid roller lifter installed on it. It's one of Blair's cam grinds that he uses on a few different things (not a 100% custom grind). If you call him I'm sure he'll sell you one. At idle it's pretty choppy. I'm not sure how happy it will be with your individual runner setup. From what I have read it seems those require more lobe separation.
CaptCobrajet
« Reply #20 on: June 04, 2021, 08:35:54 PM »
Mike is correct.  Lobe sep needs to be totally different for IR.  I usually have cams made from round lobe cores for stack injected apps.  What you really need won't fit on standard shelf cam cores.
Blair Patrick
