FE Technical Forum
Trick Flo 175 valve size question?
Topic: Trick Flo 175 valve size question? (Read 2815 times)
gregaba
August 20, 2020, 04:33:29 PM »
Anyone know why Trick flo power port 175 heads use a 1.625 exhaust valve instead of the stock 1.65?
I was thinking of ordering a set of bare heads to upgrade from the Aluminum ones I have but noticed the smaller exhaust valve size.
I just got in a new order of SI stainless valves and they are !.65 on the exhaust. Would hate to have to spend the money for a new set of exhaust's.
Summit part # TFS-5641B701-CW
Greg
Re: Trick Flo 175 valve size question?
Reply #1 on:
August 20, 2020, 04:59:28 PM »
Probably because it's a relationship between the valve size and the throat size. The ports are pretty small on the TFS stuff.
You will need different length valves as well, they are not normal FE length.
Instagram: brentlykinsmotorsports
YouTube: Lykins Motorsports
gregaba
Reply #2 on:
August 20, 2020, 05:27:57 PM »
Thanks Brent
I was thinking about buying these heads before I ordered the pistons we talked about the other day but I hate to have to order [I am cheap] new valves etc. to do that.
I know they make power because I read your post about the road race motor you dynoed and it didn't lack for power.
Thanks for clearing this up for me.
Greg
FE Technical Forum
